Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
    Originally posted by TVDroid View Post
    See my Signature, you RAM Speed is only 701 ! My is 1026.
    You use the 1.8GHz CPU and 1400MHz RAM Kernel from SAM ?
    yes, i can't find a solution! The problem is not the ram is the gpu score. I`m stuck whatever frequency i choose at 446mhz. Shit chinese crap!
      Not working for me (mk802iv) ;(
      Black screen, like it doesn't boot.
      Required to flash with 2.07 loader, but nothing on the screen, even after several minutes.
        I have the strange problem, i got 5 android stick all of them are with the same Rockchip, but some of them works perfect, and some does have the flickering problem.. all of them uses the same charger and cables but still problem..
        i hope this will get fixed
        By the way, can i do a backup on one of the other Android sticks i have that are the same ones with rockchip and, the OEM firmware from retail?
        if so is there any guide for it, so i can do a reset to factory settings on thoose sticks that does not work..
        i got 2 sticks with the same chipset Rockchip 3188T, that the screen flickers and shuts of and on every second.
          CX-919 V2.0
          hi,
          I have Cx-919 V2.0 (i dont know about "T", because i didnt tried to take off original heatsinks, i put my modification on top of original. but i think it is T chip)
          I can conform that nothing works for me atm...
          my results:
          1.) NEO 1.7 with Sams OC kernels - screen flickering
          2.) Finless 1.6b with Sams OC kernels - screen flickering
          3.) NEO 2.1 with pachomatic (tried FrankieDedo compiled kernel) - screen flickering
          4.) even tried to restore original firmware update (http://blog.geekbuying.com/index.php.../#.UvXf9PmSyFd) - screen flickering, too.
          only rom's that works without flickering are Neo 1.9a and Neo 2.0, but CPU frequency is between 1.2 - 1.43 GHz...
          yes, stick is straight in the TV (no HDMI extension cables).
          any thoughts what to try ?
            But are we sure that the RK3188-T can not be oc?
            I rom with oc minix of neo-7 can not go to 1800 mhz ... flicker-free ...
            Use the same kernel minix can help?
              Hi
              If this helps you are not alone, I have the same unit as you running the same ROM and kernel also only got 19445 my ram speed is approx. just under 900 Don't know what to do
              My CPU ARE RK-3188
              Basmand
                Originally posted by basmand View Post
                Hi
                My CPU ARE RK-3188
                Basmand
                There must be someway to unlock the gpu. For the ram, i tried a better psu and i got 980, not a big difference, but is something.
                Neomode will figure out something, he own the same device. I hope.
                  Seems like thoose who have Rockchip with the last number 1341 and under, may come across problems..
                  i got 2 of them with 1341, and i got 3 with 1345 and 1345 works great, but not 1341
                    Flash It installed?
                    Anybody know if Flash It by neomode installed in this Rom? Thanks
                    -Chromecast with Google TV
                    - Android Q Android 10
                      In the final version Yes. But in the moment I am sick and can not work on it.
                      Neomode
                      Gesendet von meinem GT-I9305 mit Tapatalk
                        Originally posted by valzja View Post
                        hi,
                        my results:
                        Use the neo x7mini firmware m8
                          please i need original firmware for the mk809iii 3188-t wifi ap6210 1348. flickering no stop with this rom, 'combo' rom neo 1.7 kernel 1.8 ghz 1400 mhz ram withe flickering problem. need the original rom please ):
                            switch screen resolution to the 1080p in the settings. Hope it help you to avoid flickering problem
                              yes i switch to 1080p and no hdmi extender but the flickering problem not stop, I have tried other rom and kernel but the problem remains I want to return to the original firmware but can not find :/
                              thanks for the response
                                mainbord color
                                2. Firmware blue mainboard: .
                                2-1 mainboard Firmware black: .
                                2-2 Firmware green mainboard:
                                Rom stock obviously
