Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
Originally posted by vihru View PostOverclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by FrankieDedo View PostMmmm...where did you have the antenna? And what type is it? I had the same problem, I had the "foil" antenna stocked to the plastic case... I solved it making a little notch into the plastic in order to pass out the cable and gluing the antenna OUT of the case, and it worked FLAWLESSLY, very good signal.. If you want to give it a try, be careful when you pry the antenna out of the case
yes but it was working before this custom rom
Originally posted by vihru View Postyes but it was working before this custom rom
Well that's weird, thenI don't know what it could be then :/
Originally posted by neomode View PostThis can happen when you have a Rk3188T CPU inside.
For me it Works. I will check it.
Neomode
it does not install them.. is there any easier way to install theese drivers? i only get unknown device
thanks in advanced
Originally posted by Lenti View PostHey NEO, why cant i install the drivers for windows 8?
thanks in advancedOverclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by Lenti View PostDarnit, haha i just updated to W8.1 thats why it does not workOverclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
NEOMODE, looks like I'm not the only one. How to fix this problem? What can you recommend ? Why it keeps rebooting? I think my CPU is Rk3188T because the highest frequency I can select - 1.6GHz. It was happening with neomode 1.9a and now with 2.1 versions. Should I throw my stick out of the window?
Just for the record: I do not have any flickering issue like the other friends are complaining. WiFi, Bluetoth are working good. So far I only miss 2 things - 1. power button on the dock. 2. missing autohide option for the action bar.
Also, when the stick is rebooted the manufacture logo displays on the TV at the left top corner. not in the middle. Do you know why?
and last: is there reason you are not working on one build/rom? You keep changing roms. You should be consistent and keep working on one rom. It will make life easier.
BTW: this dongle works perfect with my 802IV doungle
There are currently 1491 users online. 0 members and 1491 guests.
