My first one had a piss poor one and this one is darn near perfect but just incxase i got a unversal power supply as backup and iam a happy camper.
Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
Originally posted by mymkv View Postnice. I assume you are using this rom 2.1 with which kernel ? can you please post download link?
If you have a normal RK3188, i recommend a cpu frequency range between 1,0/1,2 GHz and 1,6/1,8 GHz... i tried to set the maximum freq to 1,92 GHz but it isn't really stable, and it needs much more power to run.
The best thing is to use rkpatchomatic by yourself (editing the overclockomatic source, it's really simple) and setting your own frequency steps, and choose your own GPU/RAM freq values too
Here is the kernel...
DOWNLOAD: http://www.mediafire.com/download/j2.../kernelmod.img
just to remember, the values that i have set here are:
- CPU frequency range = 1.008/1.200/1.416/1.608/1.708/1.800/1.920 GHz
- GPU frquency range = 400/600/798 MHz
- RAM frequency = 800 MHz*
*As i said before, with DDR the effective frequency is 1600 MHz (Double Data Rate) but that doesn't really matter, i guessOverclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
I have some issue with my mk809iii, I flashed it with 1.3 , 1.9, 2.0 and always it works fine.
But when I try to flash neo 2.1 i have error after reset device - it very slow reconnect and rk develop tool has error timeout waiting.
I try to flash neo 2.0 with loader 2.07 and process complete success.
But on all firmwares on loader 1.* i have error with slow finding in rk batch tool.
How can I solve this issue?
Originally posted by akp View PostI have some issue with my mk809iii, I flashed it with 1.3 , 1.9, 2.0 and always it works fine.
How can I solve this issue?Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by FrankieDedo View PostThe best thing is to use rkpatchomatic by yourself (editing the overclockomatic source, it's really simple) and setting your own frequency steps, and choose your own GPU/RAM freq values too
Or describe, how change it?
for example:
# GPU frequency cap search list
my @gpu_cap_search_list = (
[133000000, 266000000],
[133000000, 400000000],
[133000000, 466000000],
[133000000, 500000000],
[133000000, 533000000],
[133000000, 600000000],
# GPU frequency cap replacement
my @gpu_cap_replace = (133000000, 800000000);
here only frequency range, how describe steps : "GPU frquency range = 400/600/798 MHz"
and why 798, not 800 ?
and why 798, not 800 ?for the GPU ranges i used the values already contained into the overclockomatic source, and it was set at 798, sorry but i can't say you more than this :/
Anyway here is the download: https://www.mediafire.com/?wfikcwr21fo2dzf
(i commented the cpu profiles under the 1800h profile just because i wanted to write kernel faster, but i've already changed those, so if you want a lower overclock cap, you just have to remove the hash in front of it, the same for the GPU and RAM profiles)
I recommend everyone to use notepad++ to edit this, and under "Language" menu, go to "P" and then select "Perl"
here is a code version if you want to check it out on the fly
Code:#!/usr/bin/perl# # Copyright 2013 phjanderson # # This program is free software: you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License # along with this program. If not, see <http://www.gnu.org/licenses/>. # use strict; # GPU frequency cap search list my @gpu_cap_search_list = ( [133000000, 266000000], [133000000, 400000000], [133000000, 466000000], [133000000, 500000000], [133000000, 533000000], [133000000, 600000000], ); # GPU frequency cap replacement my @gpu_cap_replace = (133000000, 800000000); # these voltages are used to search for voltage/frequency tables my @volt_list = (800000, 825000, 850000, 875000, 900000, 925000, 950000, 975000, 1000000, 1025000, 1050000, 1075000, 1100000, 1125000, 1150000, 1175000, 1200000, 1225000, 1250000, 1275000, 1300000, 1325000, 1350000, 1375000, 1400000, 1425000, 1450000); # for the frequencies we just generate a list of all frequencies between 100 and 2500mhz my @freq_list; for ( my $mhz = 100 ; $mhz <= 2500 ; $mhz++ ) { push( @freq_list, $mhz * 1000 ); push( @freq_list, $mhz * 1000 + 1 ); push( @freq_list, $mhz * 1000 + 2 ); push( @freq_list, $mhz * 1000 + 3 ); push( @freq_list, $mhz * 1000 + 4 ); } # below are the profiles used for the patched kernels # please remember that they cannot be longer than the frequency tables inside the kernel you are patching # CPU profiles my %cpu_profiles = ( "cpustock" => 0, # "cpu1608h" => # [ # [1050000, 1008000], # [1150000, 1200000], # [1250000, 1416000], # [1250000, 1416000], # [1350000, 1608000], # ], # "cpu1704h" => # [ # [1050000, 1008000], # [1150000, 1200000], # [1250000, 1416000], # [1350000, 1608000], # [1375000, 1704000], # ], "cpu1800h" => [ [1050000, 1008000], [1150000, 1200000], [1250000, 1416000], [1350000, 1608000], [1375000, 1704000], [1375000, 1800000], ], "cpu1920h" => [ [1050000, 1008000], [1150000, 1200000], [1250000, 1416000], [1350000, 1608000], [1375000, 1704000], [1375000, 1800000], [1450000, 1920000], ], ); # GPU profiles my %gpu_profiles = ( "gpustock" => 0, # "gpu600" => # [ # [975000, 133000], # [1000000, 200000], # [1025000, 266000], # [1050000, 300000], # [1100000, 400000], # [1250000, 600000], # ], # "gpu600h" => # [ # [1100000, 400000], # [1250000, 600000], # ], "gpu798h" => [ [1100000, 400000], [1250000, 600000], [1375000, 798000], ], ); # DDR profiles # the final digit of the frequency signifies the following: # 1 DDR_FREQ_NORMAL # 2 DDR_FREQ_VIDEO # 3 DDR_FREQ_IDLE # 4 DDR_FREQ_SUSPEND # only 1 and 2 seem to be used in the source code for Android sticks and even though 2 is set it doesn't seem to be used my %ddr_profiles = ( "ddrstock" => 0, # "ddr400" => # [ # [1000000, 300002], # [1100000, 400001], # ], # "ddr600" => # [ # [1100000, 400002], # [1100000, 600001], # ], # "ddr667" => # [ # [1100000, 400002], # [1200000, 667001], # ], # "ddr720" => # [ # [1100000, 400002], # [1200000, 720001], # ], "ddr800" => [ [1100000, 400002], [1250000, 800001], ], ); ########## System variables ########## my %ddr_freq_type_map = ( 0 => "", 1 => "1 DDR_FREQ_NORMAL", 2 => "2 DDR_FREQ_VIDEO", 3 => "3 DDR_FREQ_IDLE", 4 => "4 DDR_FREQ_SUSPEND", ); my $freq_table_end = pack("V", 0) . pack("V", 0xfffffffe); my @crc_table = ( 0x00000000, 0x04c10db7, 0x09821b6e, 0x0d4316d9, 0x130436dc, 0x17c53b6b, 0x1a862db2, 0x1e472005, 0x26086db8, 0x22c9600f, 0x2f8a76d6, 0x2b4b7b61, 0x350c5b64, 0x31cd56d3, 0x3c8e400a, 0x384f4dbd, 0x4c10db70, 0x48d1d6c7, 0x4592c01e, 0x4153cda9, 0x5f14edac, 0x5bd5e01b, 0x5696f6c2, 0x5257fb75, 0x6a18b6c8, 0x6ed9bb7f, 0x639aada6, 0x675ba011, 0x791c8014, 0x7ddd8da3, 0x709e9b7a, 0x745f96cd, 0x9821b6e0, 0x9ce0bb57, 0x91a3ad8e, 0x9562a039, 0x8b25803c, 0x8fe48d8b, 0x82a79b52, 0x866696e5, 0xbe29db58, 0xbae8d6ef, 0xb7abc036, 0xb36acd81, 0xad2ded84, 0xa9ece033, 0xa4aff6ea, 0xa06efb5d, 0xd4316d90, 0xd0f06027, 0xddb376fe, 0xd9727b49, 0xc7355b4c, 0xc3f456fb, 0xceb74022, 0xca764d95, 0xf2390028, 0xf6f80d9f, 0xfbbb1b46, 0xff7a16f1, 0xe13d36f4, 0xe5fc3b43, 0xe8bf2d9a, 0xec7e202d, 0x34826077, 0x30436dc0, 0x3d007b19, 0x39c176ae, 0x278656ab, 0x23475b1c, 0x2e044dc5, 0x2ac54072, 0x128a0dcf, 0x164b0078, 0x1b0816a1, 0x1fc91b16, 0x018e3b13, 0x054f36a4, 0x080c207d, 0x0ccd2dca, 0x7892bb07, 0x7c53b6b0, 0x7110a069, 0x75d1adde, 0x6b968ddb, 0x6f57806c, 0x621496b5, 0x66d59b02, 0x5e9ad6bf, 0x5a5bdb08, 0x5718cdd1, 0x53d9c066, 0x4d9ee063, 0x495fedd4, 0x441cfb0d, 0x40ddf6ba, 0xaca3d697, 0xa862db20, 0xa521cdf9, 0xa1e0c04e, 0xbfa7e04b, 0xbb66edfc, 0xb625fb25, 0xb2e4f692, 0x8aabbb2f, 0x8e6ab698, 0x8329a041, 0x87e8adf6, 0x99af8df3, 0x9d6e8044, 0x902d969d, 0x94ec9b2a, 0xe0b30de7, 0xe4720050, 0xe9311689, 0xedf01b3e, 0xf3b73b3b, 0xf776368c, 0xfa352055, 0xfef42de2, 0xc6bb605f, 0xc27a6de8, 0xcf397b31, 0xcbf87686, 0xd5bf5683, 0xd17e5b34, 0xdc3d4ded, 0xd8fc405a, 0x6904c0ee, 0x6dc5cd59, 0x6086db80, 0x6447d637, 0x7a00f632, 0x7ec1fb85, 0x7382ed5c, 0x7743e0eb, 0x4f0cad56, 0x4bcda0e1, 0x468eb638, 0x424fbb8f, 0x5c089b8a, 0x58c9963d, 0x558a80e4, 0x514b8d53, 0x25141b9e, 0x21d51629, 0x2c9600f0, 0x28570d47, 0x36102d42, 0x32d120f5, 0x3f92362c, 0x3b533b9b, 0x031c7626, 0x07dd7b91, 0x0a9e6d48, 0x0e5f60ff, 0x101840fa, 0x14d94d4d, 0x199a5b94, 0x1d5b5623, 0xf125760e, 0xf5e47bb9, 0xf8a76d60, 0xfc6660d7, 0xe22140d2, 0xe6e04d65, 0xeba35bbc, 0xef62560b, 0xd72d1bb6, 0xd3ec1601, 0xdeaf00d8, 0xda6e0d6f, 0xc4292d6a, 0xc0e820dd, 0xcdab3604, 0xc96a3bb3, 0xbd35ad7e, 0xb9f4a0c9, 0xb4b7b610, 0xb076bba7, 0xae319ba2, 0xaaf09615, 0xa7b380cc, 0xa3728d7b, 0x9b3dc0c6, 0x9ffccd71, 0x92bfdba8, 0x967ed61f, 0x8839f61a, 0x8cf8fbad, 0x81bbed74, 0x857ae0c3, 0x5d86a099, 0x5947ad2e, 0x5404bbf7, 0x50c5b640, 0x4e829645, 0x4a439bf2, 0x47008d2b, 0x43c1809c, 0x7b8ecd21, 0x7f4fc096, 0x720cd64f, 0x76cddbf8, 0x688afbfd, 0x6c4bf64a, 0x6108e093, 0x65c9ed24, 0x11967be9, 0x1557765e, 0x18146087, 0x1cd56d30, 0x02924d35, 0x06534082, 0x0b10565b, 0x0fd15bec, 0x379e1651, 0x335f1be6, 0x3e1c0d3f, 0x3add0088, 0x249a208d, 0x205b2d3a, 0x2d183be3, 0x29d93654, 0xc5a71679, 0xc1661bce, 0xcc250d17, 0xc8e400a0, 0xd6a320a5, 0xd2622d12, 0xdf213bcb, 0xdbe0367c, 0xe3af7bc1, 0xe76e7676, 0xea2d60af, 0xeeec6d18, 0xf0ab4d1d, 0xf46a40aa, 0xf9295673, 0xfde85bc4, 0x89b7cd09, 0x8d76c0be, 0x8035d667, 0x84f4dbd0, 0x9ab3fbd5, 0x9e72f662, 0x9331e0bb, 0x97f0ed0c, 0xafbfa0b1, 0xab7ead06, 0xa63dbbdf, 0xa2fcb668, 0xbcbb966d, 0xb87a9bda, 0xb5398d03, 0xb1f880b4, ); ########## Functions ########## sub calculate_rkcrc { my ($data) = @_; my $crc = 0; my $data_size = length($data); my $idx = 0; for ( my $idx = 0 ; $idx < $data_size ; $idx++ ) { $crc = $crc << 8 ^ $crc_table[$crc >> 24 ^ unpack( "C", substr( $data, $idx, 1 ) )]; $crc = $crc % 0x100000000; } return $crc; } sub read_kernel { my ($srcfile) = @_; my $buffer; my $filesize = -s $srcfile; open INF, $srcfile or die "\nCan't open $srcfile for reading: $!\n"; binmode INF; read (INF, $buffer, $filesize); close INF or die "Can't close $srcfile: $!\n"; return $buffer; } sub parse_table_data { my ($table_data) = @_; my @table; my $table_size = length( $table_data ) / 8 - 1; for ( my $idx = 0 ; $idx < $table_size ; $idx++ ) { my $volt = unpack( "V", substr( $table_data, $idx * 8, 4 ) ); my $freq = unpack( "V", substr( $table_data, $idx * 8 + 4, 4 ) ); my @entry = ( $volt, $freq ); push( @table, \@entry ); } return \@table; } sub pack_table_data { my ($table_ref) = @_; my $table_data = ""; for my $entry_ref ( @$table_ref ) { my ( $volt, $freq ) = @$entry_ref; $table_data .= pack( "V", $volt ); $table_data .= pack( "V", $freq ); } $table_data .= $freq_table_end; return $table_data; } sub find_tables { my ($buffer, $freq_list_ref, $volt_list_ref) = @_; my $regex="((" . join("|", map { my $packed = pack("V", $_); "\Q$packed\E" } @$volt_list_ref) . ")(" . join("|", map { my $packed = pack("V", $_); "\Q$packed\E" } @$freq_list_ref) . "))+" . $freq_table_end; my %tables; while ($buffer =~ /$regex/gs) { $tables{ $-[0] } = parse_table_data( ${^MATCH} ); } return \%tables; } sub display_table { my ($table_ref) = @_; print "MHz\tmV\n"; for my $entry_ref ( @$table_ref ) { my ( $volt, $freq ) = @$entry_ref; print int($freq/1000); print "\t"; print int($volt/1000); if ( $freq%1000 > 0 ) { print "\t" . $ddr_freq_type_map{ $freq%1000 }; } print "\n"; } } ########## Main ########## print "=============================\n"; print "Rockchip Patchomatic Suite\n"; print "Overclockomatic RK3188 v1.2\n"; print "by phjanderson\n"; print "=============================\n\n"; if ( @ARGV != 1 ) { print "Error: no kernel image specified\n\n"; print "Please specify a kernel image file name\n\n"; exit( -1 ); } my $srcfile = $ARGV[0]; my $target_base = $srcfile; $target_base =~ s/\.[^.]+$//; my $target_ext = substr( $srcfile, length( $target_base ) ); print "Reading kernel image\n"; my $buffer = read_kernel( $srcfile ); print "Done!\n\n"; print "Searching GPU frequency limit cap\n"; my $gpu_cap_found = 0; for my $gpu_cap_search (@gpu_cap_search_list) { my $gpu_cap_search_data = pack("V", $gpu_cap_search->[0]) . pack("V", $gpu_cap_search->[1]); my $gpu_cap_search_count =()= $buffer =~ /\Q$gpu_cap_search_data\E/g; if ( $gpu_cap_search_count == 1 ) { print "Found: " . $gpu_cap_search->[0] . ", " . $gpu_cap_search->[1] . "\n"; print "Patching...\n"; my $gpu_cap_replace_data = pack("V", $gpu_cap_replace[0]) . pack("V", $gpu_cap_replace[1]); $buffer =~ s/\Q$gpu_cap_search_data\E/$gpu_cap_replace_data/g; $gpu_cap_found = 1; last; } } if( !$gpu_cap_found ) { print "Warning: unable to patch the GPU frequency limit cap!\n"; print "Searching GPU frequency limit cap (reversed)\n"; $gpu_cap_found = 0; for my $gpu_cap_search (@gpu_cap_search_list) { my $gpu_cap_search_data = pack("V", $gpu_cap_search->[1]) . pack("V", $gpu_cap_search->[0]); my $gpu_cap_search_count =()= $buffer =~ /\Q$gpu_cap_search_data\E/g; if ( $gpu_cap_search_count == 1 ) { print "Found: " . $gpu_cap_search->[0] . ", " . $gpu_cap_search->[1] . "\n"; print "Patching...\n"; my $gpu_cap_replace_data = pack("V", $gpu_cap_replace[1]) . pack("V", $gpu_cap_replace[0]); $buffer =~ s/\Q$gpu_cap_search_data\E/$gpu_cap_replace_data/g; $gpu_cap_found = 1; last; } } if( !$gpu_cap_found ) { print "Warning: unable to patch the GPU frequency limit cap (reversed)!\n"; } } print "\n"; print "Searching volt/frequency tables\n"; my $tables_ref = find_tables( $buffer, \@freq_list, \@volt_list ); my %tables = %$tables_ref; print "Done!\n\n"; if ( scalar keys %tables < 3 ) { print "Error: found only " . ( scalar keys %tables ) . " frequency tables, at least 3 are needed\n\n"; exit( -1 ); } print "Volt/frequency tables found in the image:\n"; my $table_idx = 1; my %table_idx_offset_map; for my $offset ( sort { $a <=> $b } keys %tables ) { my $table_ref = $tables{ $offset }; $table_idx_offset_map{ $table_idx } = $offset; print "== Table $table_idx at offset $offset ==\n"; display_table( $table_ref ); print "\n"; $table_idx++; } print "== End of tables ==\n\n"; print "Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel.\n\n"; my $input; my $cpu_table_offset = 0; do { print "Which table is the CPU table?\n"; print "(The CPU table is mostly the largest table ranging from 312 to 1608 MHz)\n"; chomp ($input = <STDIN>); if ( exists $table_idx_offset_map{ int($input) } ) { $cpu_table_offset = $table_idx_offset_map{ int($input) }; } else { print "Table does not exist.\n"; } print "\n"; } until ( $cpu_table_offset != 0 ); my $cpu_table_ref = $tables{$cpu_table_offset}; my $cpu_table_length = @$cpu_table_ref; my $gpu_table_offset = 0; do { print "Which table is the GPU table?\n"; print "(The GPU table is mostly the second largest table ranging from 133 to 600 MHz)\n"; chomp ($input = <STDIN>); if ( exists $table_idx_offset_map{ int($input) } ) { $gpu_table_offset = $table_idx_offset_map{ int($input) }; } else { print "Table does not exist.\n"; } print "\n"; } until ( $gpu_table_offset != 0 ); my $gpu_table_ref = $tables{$gpu_table_offset}; my $gpu_table_length = @$gpu_table_ref; my $ddr_table_offset = 0; do { print "Which table is the DDR table?\n"; print "(The DDR table is mostly quite short, mostly 2 entries, and can be recognized by the labels DDR_FREQ_... at the end of each line)\n"; chomp ($input = <STDIN>); if ( exists $table_idx_offset_map{ int($input) } ) { $ddr_table_offset = $table_idx_offset_map{ int($input) }; } else { print "Table does not exist.\n"; } print "\n"; } until ( $ddr_table_offset != 0 ); my $ddr_table_ref = $tables{$ddr_table_offset}; my $ddr_table_length = @$ddr_table_ref; print "Patching kernels... please wait...\n\n"; foreach my $cpu_profile_key (keys %cpu_profiles) { foreach my $gpu_profile_key (keys %gpu_profiles) { foreach my $ddr_profile_key (keys %ddr_profiles) { my $target_buffer = $buffer; my $cpu_profile_table_ref = $cpu_profiles{ $cpu_profile_key }; my $cpu_profile_table_length = 0; if ( $cpu_profile_table_ref != 0 ) { $cpu_profile_table_length = @{$cpu_profile_table_ref}; } my $gpu_profile_table_ref = $gpu_profiles{ $gpu_profile_key }; my $gpu_profile_table_length = 0; if ( $gpu_profile_table_ref != 0 ) { $gpu_profile_table_length = @{$gpu_profile_table_ref}; } my $ddr_profile_table_ref = $ddr_profiles{ $ddr_profile_key }; my $ddr_profile_table_length = 0; if ( $ddr_profile_table_ref != 0 ) { $ddr_profile_table_length = @{$ddr_profile_table_ref}; } if ( $cpu_profile_table_ref != 0 ) { if ( $cpu_profile_table_length > $cpu_table_length ) { print "ERROR: CPU profile table $cpu_profile_key is larger than the CPU table in the kernel"; exit -1; } else { my $new_cpu_table_data = pack_table_data( $cpu_profile_table_ref ) . ($freq_table_end x ($cpu_table_length - $cpu_profile_table_length)); my $new_cpu_table_data_length = length( $new_cpu_table_data ); $target_buffer = substr( $target_buffer, 0, $cpu_table_offset) . $new_cpu_table_data . substr( $target_buffer, $cpu_table_offset + $new_cpu_table_data_length); } } else { #print "CPU stock mode, not patching the CPU table\n"; } if ( $gpu_profile_table_ref != 0 ) { if ( $gpu_profile_table_length > $gpu_table_length ) { print "ERROR: GPU profile table $gpu_profile_key is larger than the GPU table in the kernel"; exit -1; } else { my $new_gpu_table_data = pack_table_data( $gpu_profile_table_ref ) . ($freq_table_end x ($gpu_table_length - $gpu_profile_table_length)); my $new_gpu_table_data_length = length( $new_gpu_table_data ); $target_buffer = substr( $target_buffer, 0, $gpu_table_offset) . $new_gpu_table_data . substr( $target_buffer, $gpu_table_offset + $new_gpu_table_data_length); } } else { #print "GPU stock mode, not patching the GPU table\n"; } if ( $ddr_profile_table_ref != 0 ) { if ( $ddr_profile_table_length > $ddr_table_length ) { print "ERROR: DDR profile table $ddr_profile_key is larger than the DDR table in the kernel"; exit -1; } else { my $new_ddr_table_data = pack_table_data( $ddr_profile_table_ref ) . ($freq_table_end x ($ddr_table_length - $ddr_profile_table_length)); my $new_ddr_table_data_length = length( $new_ddr_table_data ); $target_buffer = substr( $target_buffer, 0, $ddr_table_offset) . $new_ddr_table_data . substr( $target_buffer, $ddr_table_offset + $new_ddr_table_data_length); } } else { #print "DDR stock mode, not patching the DDR table\n"; } my $crc = calculate_rkcrc( substr( $target_buffer, 8, -4 ) ); $target_buffer = substr( $target_buffer, 0, -4 ) . pack( "V", $crc ); my $target_file = $target_base . "_" . $cpu_profile_key . "_" . $gpu_profile_key . "_" . $ddr_profile_key . $target_ext; print "Writing $target_file\n"; open OUTF, ">$target_file" or die "\nCan't open $target_file for writing: $!\n"; binmode OUTF; print OUTF $target_buffer; close OUTF or die "Can't close $target_file: $!\n"; } } } print "\nAll done!\n";
hi to all from finland.. i registered because if i can get help from here..
i have MK802IV with CPU RK3188 Quad core... and i have flashed newest stock firmware for that..
still i think that youtube and games are not faster enough :/ videos are lagging.. etc..
so is there any fix for that? thanks a lot! could this rom help me?
EDIT: i flashed this rom. but no wifi.. it doesnt connect my wlan.. so this might be good if wifi would be fixed someway.. tried flashing twice and making recovery... no help for that.Last edited by vihru; 03 February 2014, 18:13.
Re: Neomode Custom Rom MK802IV / MK809III 2.1 BETA RK3188-T and RK3188
Originally posted by FrankieDedo View PostYes, i'm using the 2.1 beta, with the kernel.img you find into the rom .zip as i said i used rkpatchomatic on it... anyway, here is the download.... oh, and obviously BE CAREFUL!!! Don't come here and say that i ruined your stick
Originally posted by vihru View Posthi to all from finland.. i registered because if i can get help from here..
Ynot.
There are currently 1902 users online. 3 members and 1899 guests.
