NEW - MK908 Finless 1.8 ROM
Originally posted by britoso View PostGood to know. I also read that hardware acceleration may be a problem.
Originally posted by EzerchE View Post
Is this the stock firmware from Tronsmart? Why use that rather than a customized one?
I was planning on using this one: mk908_422jb_finless_18
MK908 & touch screen zaagtech
Hello Bob,
I have a MK908 V5 and I can not find any ROM that is able to operate the touch screen driver of zaagtech. In the past I used a MK908 and everything worked properly.
This problem was also discussed in this post: http://www.freaktab.com/showthread.p...th-touchscreen
I have tried many roms on my MK908 but none, so far, able to run the driver correctly.
Let me explain: actually the application that manages the touch screen starts successfully, the pointer follows the movement of the fingers but it seems that there is no effect on the operating system.
Do not execute the click and swipe.
I want to ask if there is a rom "clean", without application like XBMC or media player or other customizations.
I need only basic android, although it is not rooted.
Sorry if I was not clear enough.
Thanks for your time.
Greetings.
Stefano
No boot sound!
Hi, I just got A MK908v3 and decided I would test this ROM out. One thing I noticed is we can now have a sound file(MP3) play while the device is booting. I can see that in this ROM "Adele_Rolling_in_the_Deep" should be playing when booting up, but I don't hear anything. Anyone else have this problem?
Just noticed that when hitting power off, it sits at the powering of message for a few seconds then locks up.Last edited by shatterstar78; 06 July 2014, 15:50.
I just got my MK908 the other day and installed Finkless great Rom. Everything seems to work fine, but I got one big problem: I can't activate bluetooth.
I bought an TeckNet X340 and would like to connect it with the stick. Whenever I go to settings, I can't turn on BT. Just nothing happens.. I have a PC keyboard connected via USB, but a connection via BT would be great. Any ideas how to turn BT on??
tia!
Originally posted by akismal View PostIs there any way to autohide status bar while xbmc is loading?
Download https://play.google.com/store/apps/d...llScreen&hl=de and set it to Autostart.
Wait till Android is fully loaded and the Statusbar is gone, than start XBMC.
There are currently 1914 users online. 0 members and 1914 guests.
