NEW - MK908 Finless 1.8 ROM
Originally posted by Finless View PostYes actually coming from KK back to JB is a problem. I brick my device EVERY TIME!
You have to put it in MASK ROM mode by shorting NAND pins. It's because of the loader.
PAIN in the ass but fact. The loader will not downgrade without MASK ROM mode
I also keep getting download image failed but I'm coming from stock JB rom. How can this happen?
Originally posted by pesanet View Posthi
why isn't there estonian language support?
--Andrisoterwise we could provide very helpfull and great support such as general help, custom rom made by awsome if not best developper of the scene comparate to factory one most of case.. and friendly helpful users
Best friendly regards to estonians from freaktab members
Vpn connection impossible
I've got a problem with this Rom.
I successfully installed it after a few hard days but it's allright, this rom is really greater than the stock rom.
I installed OpenVPN connect but the MK908 crashes when the VPN tries to connect to a server.
With OpenVPN, the MK908 freezes.
Does anyone has a solution please ?
AW: NEW - MK908 Finless 1.8 ROM
tapatalked from i9300
Originally posted by FadeFx View PostJust read a page or two before posting next time. There is a solution for you.
Sorry I used search function but it didn't return any answer.
Thank you for your response, I'm going to try this now.
Edit : It's OK, thanks for the adviceLast edited by spinman; 04 June 2014, 16:25.
Wrong USB Cable
Thanks Bob,
I had been using 1.7a for some time, Went to try to upgrade to 1.8 and when I put the 908 into Flash mode the pc would not recognize it. I tried to re-install the driver. Kept getting an error saying no driver was found. I tried everything for hours.then, after I gave up and hooked it all back up, walked away. Something said,
try a different usb cable. and dang if that work right off the bat
. The other cable is working fine for everything else. but not to flash the 908. Go figure.
Just thought I would share that tidbit in case someone else ran into problems. Oh, and send out a very well deserved THANKS to Bob.
Regards
Tom
I'm new..
Just an FYI, if you intend on getting the MK908 from geekbuying, they're being sold with rk3188t in them and are therefore capped at 1.4GHz. I tried using the overclock kernels but they resulted in a blank screen and what appears to be a bootloop (blue LED flashes on and off).
To be honest, I have mixed feelings about this device. Stock ROM was completely unusable (massive UI lag and hangs) and with the Finless 1.8, less so. 1080p video works but only if you can tolerate UI glitches every so often and wifi/bluetooth performs just as poorly. With Antutu, I get a score of about 14000~ and other minor annoyances such as the lack of "lockscreen" security (even 3rd party apps don't work). Maybe it requires abit more fiddling around but overally, it's an average device.
If anyone has any pointers in tolerating a "crippled" stick, let me know. I'd appreciate it.
Kudos to Finless for making this more useable.
Originally posted by Nevezen View PostJust an FYI, if you intend on getting the MK908 from geekbuying, they're being sold with rk3188t in them and are therefore capped at 1.4GHz. I tried using the overclock kernels but they resulted in a blank screen and what appears to be a bootloop (blue LED flashes on and off).
Originally posted by FadeFx View PostDid you buy the device advertized as a 1600mhz device? If so, you could try contact geekbuying anf complain to them, probably you get a replacement
------------- Begin message -------------
Dear Friend
Greeting from geekbuying,we are writing because we got the feedback from you,first,the rk3188T you mentioned,the item came with RK3188 chip before,only the new stock come with rk3188t.and no big difference between them.we do apologize for the wrong info.
and do you like it?if not,we can offer a refund for you,could you help to ship it back,thanks
Gary
------------- End message -------------
Re: NEW - MK908 Finless 1.8 ROM
In comparison I have a 1.8 ghz quad core tablet and it stutters a little in hd on the later Netflix versions, so definitely a poorly written app.
As you rightly say out of the box the crippled versions are really bad but with this ROM mine became really good. I always fully shut down/kill background apps when I have finished with them though so I have very little multi tasking going on. But even not doing that doesn't seem to affect it too much.Last edited by dibnah; 08 June 2014, 10:34.
Originally posted by Nevezen View PostJust an FYI, if you intend on getting the MK908.......I tried using the overclock kernels but they resulted in a blank screen and what appears to be a bootloop (blue LED flashes on and off).
There are currently 2192 users online. 2 members and 2190 guests.
