Is there anything that can be done?
NEW - MK908 Finless 1.8 ROM
thanks Bob and mhkao2100
Originally posted by mhkao2100 View PostI have encounter same problem too, the parmeters file of 4gb & 6gb is wrong.... change the system partiton size from 0x120000 to 0x130000 will make it work! for example: 0x00130000@0x00884000(system),-@0x009B4000(user)
Finally flashed this rom and am amazed atm, will see how it behaves in the next days
Edit: only issue i see for now is that wifi disconnects when bluetooth is enabled, but afterwards it reconnects and is permanently functional in parallel, which was not the case before.
tapatalked from i9300
You can flash firmware from recovery that is not an update.zip? Didnt even boot to recovery once yet, but i am pretty sure you need a cwm based recovery to take nandroid backups, and afaik finless doesnt include cwm in his rom.
So if you see screen flickers in cwm recovery, you need to talk to the recovery maker, as it has its own kernel which needs hdmi voltage to be corrected.
I talked to Bob just page before and he said that he left recovery as it is but will try to make new one with CWM or TWRP.
So, I have this problem with this recovery (original). I have same problem when ROM boots up for first time but when I change resolution to 1280x720@60 everything is OK. Tested on three TV's and only one didn't have that problem.
Loaded this up a few times on my MK908v3. Started with the 1080p boot and 1080p kernel, but it looked a little off to me - everything just seemed way too big, so instead opted for the 720p boot and 1080p kernel - which looked a nicer fit for me.
I did however try an overclock kernel (went for the max - kernel1080_cpu1800h_gpu600_ddr667.img) but am seeing quite a few reboots in general use - air mouse cursor hangs, then just reboots...
Anyone else seeing this, and if so, in which kernel(s)? Which one(s) are working for you guys?
Is it possible to reflash *just* the kernel, and so not have to restore everything again?
AW: NEW - MK908 Finless 1.8 ROM
Originally posted by plinkykev View PostLoaded this up a few times on my MK908v3. Started with the 1080p boot and 1080p kernel, but it looked a little off to me - everything just seemed way too big, so instead opted for the 720p boot and 1080p kernel - which looked a nicer fit for me.
Originally posted by plinkykev View PostCool, thanks. Maybe i'll load some up and run then for a day or two to see which are OK, then post the results.
ROM is now re-uploaded WITH fixed parameter files!
There are currently 1488 users online. 2 members and 1486 guests.
