NEW - MK908 Finless 1.8 ROM
Originally posted by nntvog View PostBob,I think there there is a problem with the parameter4gb. If I do the maths correctly, the user partition should be 0x009A4000 and not 0x009B4000.
I flashed the parameter4gb and doesnt boot. It show the boot screen with the red "freaktab.com ". There maybe some other problem. I changed to 0x009A4000 and still doenst boot.
Originally posted by freakkid View PostNow a warning to all going from kitkat back to JB.
DO NOT load up the JB ROM kit and erase NAND. Load up the KitKAt ROM kit, erase NAND, then exit. Now run the JB ROM kit and flash the ROM. This should keep you from hard bricking..
Originally posted by mhkao2100 View PostI have encounter same problem too, the parmeters file of 4gb & 6gb is wrong.... change the system partiton size from 0x120000 to 0x130000 will make it work! for example: 0x00130000@0x00884000(system),-@0x009B4000(user)
Yes I see I made a math mistake in parameter file.
I will fix it and re-upload!
For now, here is a download for the fixed 4gb and 6gb parameter files:
ROM -> Fixed 4gb and 6gb parameter files
Originally posted by Ploggy View PostHi guys just updated, using the 1.8 CPU Overclock version but Atutu still only see's the CPU as 1.4?
I got Mk908 V5 BTW. Am I doing something wrong or are any of you with a V5 having the same issue?
There are currently 2269 users online. 0 members and 2269 guests.
