NEW - MK908 Finless 1.8 ROM
Originally posted by yacir View Post
Tronsmart MK908II
Kernel:
3.0.36+
sz_V_105j2#17
Vendor Software version:
205j2 17-12-2013
In order to upgrade the firmaware, I'm trying to put the device into flash mode.
no matter what Id o, i cannot get it recognized by the windows 7 PC. (i have been using the reset button with the USB cable connected to OTG port)
There is a “connect to PC” checkbox in Settings. should it be checked to be able to be detected by PC? I find that when i checked it, next time i reboot the device, it becomes unchecked. is it something preventing it to be recognized by the PC?
can anyone give me an idea why is it like that? am i missing something?
pardon me if I'm missing some fundamental ... i'm new to these stuff.
For what it's worth 1.8 is working very well for me. I have tested Netflix HD, Youtube HD, Newsy app, locally loaded 1080p files etc. Wifi is getting 20%-30% faster throughput. I believe my previous ROM (1.6a) had some issues beyond the poor internal antenna that was causing me to get no more than 5mbps on a very solid connection. Now I can achieve around 15mbps.
Bluetooth also tested fine with no interruptions or playback issues. I even used Bluetooth while Netflix streaming with no hiccups. Have also verified the device stability after approximately 2 hours - one of which I tested HD .mp4 playback from SD. No reboots so far or heat issues.
Other things; device bootup time is much faster now. I get a working OS at 35 seconds or so whereas before it took a minute or more. The boot animation is also much nicer than before.
I'm really digging this release so far Bob, can't wait for your MK908 Kitkat release, no matter how long it takes!
wifi and usb/ethernet very very slow ... when they work !
First I want to thank you for your backup tool !!! it works very well !!!
I tried your 1.8 rom, with stock, custom and OC kernel, and I have this connection problem like the 1.7 ...
Wifi or usb/ethernet connection very very slow ... when it works ...
So I put back my configuration I had before with your backup tool ...
Just for info ...
AW: NEW - MK908 Finless 1.8 ROM
Originally posted by fatbasket View PostIs it possible to change the mouse pointer size in this ROM - I'd like to make it smaller.
Use 7zip to open/modify the apk on a pc, resize the graphic and replace the apk on the stick using any root enabled filemanager. Dont forget to set file permissions as they have been before and reboot.
tapatalked from i9300
Originally posted by FadeFx View PostYou would need to edit the graphic itself, it is located in system/framework/framework-res.apk in res/mdpi/ but i dont remember the exact filename in there.
Sorted, thanks for your help.
There are currently 2170 users online. 1 members and 2169 guests.
