So if there will be an option in settings, it can be great to support these models as well.
NEW - MK908 Finless 1.8 ROM
AW: NEW - MK908 Finless 1.8 ROM
Originally posted by smallishzulu View PostI know it does not. But this FW works on MK918 or on equivelant series.
tapatalked from i9300
Rk3188T support
Can i install this on new Rk3188T chip from Geek buying?Get 15 GB Free Cloud Storage on Copy.
https://copy.com?r=ihG93E
Thank you
Sent from my GT-I9300 using TapatalkGet 15 GB Free Cloud Storage on Copy.
Originally posted by canford View PostHi guys I have wired connection using a Micro USB LAN/ethernet adaptor on this rom but are only getting 5 mb on a 100mb connection and the wifi connection is getting over 10mb, has this rom got any restrictions.
Good afternoon! (Sorry for my English - Google translation).
MK908 V5 using a fixed frequency of 1.6 GHz processor on the stock. After installing MK908 Finless 1.8 ROM stick behaves consistently, after a few minutes - restarts. I suspect that it is worth RK3188T (there was a time issue MK908 V5, and then when further production RK3188T set at a fixed frequency of 1.4 GHz). The testing process is broken in AnTuTu. Most positive in this firmware - this video, which has a smooth character view (no skipping frames). In stock this smooth video - no!
Big request to Bob:
1. For MK908 V5 (1,6) - add kernel with a frequency of 1.6 GHz.
2. For MK908 V5 with a fixed frequency of 1.4 GHz - add kernel with a frequency of 1.4 GHz.
Question to Bob - can I install firmware on MK908 MK908-II - Finless 1.6 ROM???
Help All Bob! Who uses MK908 V5 can not install your custom firmware. MK908 Finless 1.6a ROM (here also smooth video) for version V5 - taboo.
All your firmware can only be installed on V3-version.
For earlier - thank you, waiting for your answer!
Originally posted by canford View PostThanks lads will try find out what version I got!
Can anyone help me out with a couple of extra OC kernels for V1.8? (I'd do it myself if I only knew how!)
My MK908 just won't do 1800Mhz CPU, so all the included OC kernels in 1.8 don't work. It will however do 600/798GPU and 666/800 DDR. I used to run the hybrid rom OC at these levels with no issues.
If anyone could help with modding the OC kernels from Finless 1.8 that would be great:
1080p - 1600CPU / 600GPU / 666DDR
1080p - 1600CPU / 600GPU / 800DDR
1080p - 1600CPU / 798GPU / 800DDR
1080p - 1704CPU / 600GPU / 666DDR
1080p - 1704CPU / 600GPU / 800DDR
1080p - 1704CPU / 798GPU / 800DDR
Thanks in advance!
Bob this is the best ROM ever.
I'm reading about the flickering issues,I don't know if this is the same flickering all people are talking,but I have "resolution" issues.
I have 5v 2A power source that connected to the MK908
from time to time it looks like my TV is searching for new resolution mode, and it stuck on source mode that it is unknown.
my TV is 720p but I'm using 1080p kernel, so I don't know if this is the problem.
my question if i can set the resolution to permanent one that it will not started to scan every few second?
Thanks,
Robbie
Originally posted by djinnuk View PostCan anyone help me out with a couple of extra OC kernels for V1.8? (I'd do it myself if I only knew how!)
Thanks in advance!
kernel720_cpu1600h_ .... . img
kernel1080_cpu1600h_ .... img
and where there is a fixed frequency of 1.4 GHz processor:
kernel720_cpu1400h_ .... . img
kernel1080_cpu1400h_ .... img
Bob, help , please ... add the necessary firmware kernel.
There are currently 2153 users online. 1 members and 2152 guests.
