Thank you in advance.
NEW - MK908 Finless 1.8 ROM
Originally posted by ffroms View PostI would be great. If you can put TWRP into recovery or CWM. What ever you prefer.
OK I just did a 100% comparison of the 3/10 ROM and the 3/17 ROM from Beelink.
Boot.img is 100% the same....
Kernel is 100% the same.....
They did not even change build.prop and the date! Stock build.prop still says 204j2 dated 20140307
System.img the ONLY difference is in /media/audio/ringtone and /media/audio/notifications they had some duplicate file names for some sounds. The same file is there with a upper case first letter and a lower case one. like arcturus.ogg and Arcturus.ogg
NO BIG DEAL! Does NOT even effect how it works!!!!!
Recovery.img 100% the same.
So, there is no reason to do another ROM based on the 3/17 release because nothing is different other than the sounds files which again DO NOT cause any problem!
Thanx Bob for this needed mod...However I keep getting download image failed in my Flasher status right after checking the kernel...notice the download states zip is 348 megs but I am getting 337 MB
re-downloaded zip twice, still no go..
By the way I am coming from Kitkat but it should not matter..
Originally posted by freakkid View PostThanx Bob for this needed mod...However I keep getting download image failed in my Flasher status right after checking the kernel...notice the download states zip is 348 megs but I am getting 337 MB
You have to put it in MASK ROM mode by shorting NAND pins. It's because of the loader.
PAIN in the ass but fact. The loader will not downgrade without MASK ROM mode
Originally posted by canford View PostBo just a quickie how do you: MASK ROM mode by shorting NAND pins, thanks.
Basically you have to take your device apart.
Find the NAND chip.
Short pins 8&9 on the chip with a pin. count down from the round DOT on the chip.
Plug in the device to USB OTG while shorting the pins.
ROM flash tool should say "MASK ROM"
Originally posted by Finless View PostI would repost this but right now I do not have time. Search UNBRICK.
Find the NAND chip.
DO NOT load up the JB ROM kit and erase NAND. Load up the KitKAt ROM kit, erase NAND, then exit. Now run the JB ROM kit and flash the ROM. This should keep you from hard bricking..
Originally posted by freakkid View PostNow a warning to all going from kitkat back to JB.
Thank you!
Bob,I think there there is a problem with the parameter4gb. If I do the maths correctly, the user partition should be 0x009A4000 and not 0x009B4000.
I flashed the parameter4gb and doesnt boot. It show the boot screen with the red "freaktab.com ". There maybe some other problem. I changed to 0x009A4000 and still doenst boot.
There are currently 2097 users online. 0 members and 2097 guests.
