NEW - MK908 Finless 1.8 ROM
Wifi failure---MK908 V3 with AP6210
Wifi is weak, sometime stop.(AP disappeared)
Flash with 1080p. Manufacturer rom:http://www.netxeon.com/article.php?id=89Last edited by bryanhk; 03 April 2014, 13:07.
thumbs up
heya finless..
upgraded my 1.7 to 1.8 on the default setting..
just changed the 720 kernel and boot to 1080 as this device is going to a friend of mine as a birthday gift.
Noticed on my 720 tv that the screen blacks out every so many seconds, but that's fine when I set the screen HDMI back to 1280x720p-60 (that way I can finish installing this and set it back to 1080 before I power down and birthday wrap this stick)
Don't know if that's normal behavior, so thought best to mention
Thanks for another fine rom!
Originally posted by plinkykev View PostI did however try an overclock kernel (went for the max - kernel1080_cpu1800h_gpu600_ddr667.img) but am seeing quite a few reboots in general use - air mouse cursor hangs, then just reboots...
The only "stable" rom has been jjhmod for me http://www.freaktab.com/showthread.p...l-Rom-Download!
Hoping there will be a final 4.4 soon for v3, I am not even bothering about the beta
Originally posted by Psykroro View PostHi,
Nice job, flash went well with last upload.
But... I feel that wifi is slower than with 1.7... My Plex client is stuck getting 1080p running when it was smooth before...
I'll try to come back to 1.7 and cross check...
BR
Psy
During the flashing back to 1.7a I remembered that we don't have the same OC available as with 1.8.
I'm running CPU@1800/GPU@798/DDR@720 on 1.7a, @Bob : May I ask you the same OC for 1080p/1.8 kernel to test ?
As it's working back now this is not urgent (my wife and my daughter are happy so I have less pressure
Many thx
Psy
AW: NEW - MK908 Finless 1.8 ROM
Originally posted by Psykroro View PostJust back to 1.7a and I have the same wifi performance as with 1.8 BUT Plex client (same version as before) is able to run 1080p @20Mbs smoothly...
Many thx
Psy
tapatalked from i9300
Originally posted by FadeFx View PostI am not sure, but i think oc us not recommended without a cooling mod. I use my v3 with standard 1080p kernel and all looks good for now
They all reboot lots, at idle, navigating menus, watching videos (mix of resolutions) in MX Player and BS Player.
I've dropped back to the standard 1080p version and it's a lot better, but still seeing some reboots. Are there any log files I can submit or apps to load to trap these reboots and report the issues? Anyone got a 100% stable version? It works OK for me but it's pissing off my kids when it reboots in the middle of their videos!
Originally posted by plinkykev View PostOK, i've tried all the 1080p ROMs and all seem unstable on my fairly stock MK908v3 (no cooling mods, just hardwired external wifi antenna).
And yes, different ROMs can demand more power so just because one ROM worked does not mean you don't have a power issue. Eliminate that just to be sure.
BTW I am glad I don't have a V3, that version has been a problem since it came out! Touchy damn thing!
Originally posted by Finless View PostI would try another powers supply. Stability issues like this usually is a power problem.
Hello,
I have a mk908 v5, to make it run correctly I tried a lot of rom during 2 month ...
It works now, just a heat problem, but I take a PC fan and a usb cable, to make a usb fan and now it's ok.
I want to try this new Finless 1.8 rom, but before I erase my device, I want to know if there's a tool to back up all ... you never know ... if 1.8 is not ok for me ...
There are currently 4028 users online. 0 members and 4028 guests.
