Is there any customs kernels ou there for this awesome rom ?
Pipo M9 Pro RileyROM 2.7 KitKat
Originally posted by blusydays View PostI had the same issues when I tried to flash the rom under Windows 8.1, I tried on my father's computer with Windows 7 and everything went correct.
Try to switch to Win7 or find another computer under win7 and you'll be able to flash
I was also doing this on Win 8.1!
The thing is I have 2 desktops and 1 laptop in the house, all on Win 8!
Or try on w8 running as administrator and compatibility mode
Foz
Waiting patiently for your release Randy
Foz
Furthermore you'll have to edit the flash tool's ini. Change SUPPORTUSB11= to SUPPORTUSB11=1
It works, i'm flashing my M9 pro with windows 8.1 64bit right now.
But if you dont COMPLETELY understand what you are doing to your windows, grab a spare laptop or or old pc or something and install a 32bit windows 7. It's faster and you won't **** up your windows 8.1A VM won't work, there is simply no way to connect that non-working usb device to the VM (and i tried for a long time).
Then again, this got nothing to do with this rom, it's a general windows/driver problem. I think any further questions should be posted in a separate thread.
Originally posted by M-M-C View PostThat won't work, i tried. The answer is bit techy, additionally you'll have to disable driver signing in windows if you are running 64bit.
did you install the latest vmtools?
i was able to flash mine on w7 64bit without problems
but not tested it on w8.1
foz
Does anyone want to test v3.0?
Download
I haven't been able to boot it on my M7 Pro. I hope it's just a compatibility issue with my tablet.Randy
There are currently 2155 users online. 0 members and 2155 guests.
