Pipo M9 Pro RileyROM 2.7 KitKat
    It look like a new KitKat release:
    Changelog: M9pro Chinese generic version of the firmware upgrade
    Update: Upgrade to Android 4.4 system
    Updated with new UI interface
    Increase boot guide
    That look's to me like a final KitKat release from Pipo, for Chinese users.
    Probably we'll see after a few days an international release...maybe one of the last for Pipo RK3188 based devices "Update: Upgrade to Android 4.4 system".
    百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。现在注册即有机会享受2T的免费存储空间
      Did you follow procedure exactly?
      Originally posted by lunatictr View Post
      I wantted to fool around with the RR 2.7 before flashing with comming RR 2.7.3 and change Dalvic to Art. It did the apk upgrading . I then rebooted and it upgraded again. Then something happened and I needed to reboot it using the reboot apk. It got stuck there. I reseted using the back reset hole. Because of a previous encounter with a faulty charger, it goes in to charging mode when I turn it off or reset it. I have to long press the power button to boot it. However, after switching to ART, the power button is not responsive. Basicly, I have a tablet that is stuck in charging mode and I cannot turn it on without using the power button. I am not sure if it will boot to flash mode if I hard reset it with jumping some legs. Any suggestions are welcomed.
      I have switched to ART on v 2.7.2 and it seems to work fine. Only upgraded once. Have switched back to Dalvik and then to ART again. I would be very cautious about shorting out legs - one mistake and you have a permanent dead tablet; have seen instructions on this somewhere but also vaguely recall some discussion/differing views about which legs! Perhaps try reloading firmware 2.7.2?
        new KitKat for m9po on Pipo site
          It's the same than in post 376!
            I wish I could but I cannot flash it without turning it on. I am still trying.
              Doesn't work!
              This KitKat ROM is based on a new KitKat firmware dated 3/20/14. Thanks to Freaktab member Manao for contributing the link to this firmware.
              Although we have never communicated, and I made my ROM before discovering this was an already customized version...I want to thank Chinese developer Edge Xuan for his work in streamlining and beautifying the icons in this firmware. I don't usually mess around with another developer's work, but this time I made an exception (Edge Xuan, I hope it's OK).
              I wish I could say what is new with this release, but since I have no change log...we shall have to find out on our own. I do know there is a new kernel in the ROM.
              CAUTION: This IS a KitKat ROM...so do your homework on flashing KitKat ROM's before you get started.
              NOTE: I discovered a few problems with the first version (you can see my posts below), so this is now v2.7.1. Really, the only difference in the update was to remove a couple of Chinese apps I missed in the debloat process...and add the English keyboard back into the ROM.
              The main reason for this new ROM is because it contains a new kernel.
              This ROM has all of the usual RileyROM features:
              Rooted
              Debloated
              Init.d support with Busybox commands
              English Default
              Google Play Store fixes
              Updated Google Apps
              2, 4, 6, 8 or 12gb user app space by selecting the desired parameter file
              Auto Install feature added for installing apk files on first boot from external SD
              TWRP recovery installed on first boot by Abdul_Pt
              Reboot app by Petrus
              New boot animation by me
              Latest revision of the First Time User's Guide
              Flash Tool by Finless
              All made with a variation of 900SuperSport's Freaktab Kitchen
              Download
              Edit:
              I was able to download a copy of the original firmware this Edge Xuan ROM was derived from. So I have made a whole new version of the RileyROM with it. I have tested this ROM on my M7 Pro, and everything seems to work just fine.
              If you are having any problems with the 2.7.1 version, please try version 2.7.2.
              v2.7.2 Download
              Please donate to support RileyROM's on Freaktab.
              Hi man!
              Today I decided to flash your ROM. Unfortunately couldn't go through. I receive errors during this process. First I connect my Pipo M9Pro via USB, connection established, Debuging enabled, then I run ROM_Flash_Tool_137.exe. After clicking on Reboot to flash mode window pops up with the message Device can noto do switch, because of no drive. I follow then further instruction, open RKBatchTool.exe, device connected, click Switch. After that tablet is turning off and never rebooting in flash mode.
              If i manually flash (m9pro I hold power+esc few scond) I also can not do anything because ROM flash tool doesn't see my tablet in that mode.
              The end. PLEASE HELP!!!!!
                Increase boot guide
                http://pan.baidu.com/share/home?uk=1...ategory/type=0
                MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                  Be looking for a new RileyROM tomorrow.
                  Sent from my 709_v92_jbla858 using Tapatalk
                  Randy
                    Re: Pipo M9 Pro RileyROM 2.7 KitKat
                    Look forward to it.
                    Thanks!
                    LDN
                      [QUOTE=rrileypm;183179]Be looking for a new RileyROM tomorrow.
                      Thank you. Very quick response !
                        Originally posted by wolfdesignplus View Post
                        Hi man!
                        Debugging has to be turned off.
                        Randy
                          New KK rom for our m9pro, bring it on randy!
                          Sent from my M9pro using Tapatalk
                          PROUD owner of PiPO M9 Pro
                          PiPO P9 best tablet ever owned!!!
                          PiPO Tablet Freak and Flashaholic!
                            I receive errors during this process.... After that tablet is turning off and never rebooting in flash mode.
                            apparently you did something wrong. I flash this firmware my tablet and everything worked perfectly!
                            but then I decided to experiment. using non-native systems from another tablet. and got a brick.
                            then restored. but recovery had to disassemble the tablet. find the chip. close to her two contacts. tablet enters the programming mode. then flash.
                            disassembly video you are don't need full disassembly. only halfing
                            more here (in Russian!).
                              Hi man!
                              I had the same issues when I tried to flash the rom under Windows 8.1, I tried on my father's computer with Windows 7 and everything went correct.
                              Try to switch to Win7 or find another computer under win7 and you'll be able to flash
