and can smb give me build.prop file from Pipo M9 Pro RileyROM 2.7 KitKat .thanks
I'm still playing around with the quick office problem. I had to do a project last night at work...and didn't have any time last night.Randy
Originally posted by rrileypm View PostI'm still playing around with the quick office problem. I had to do a project last night at work...and didn't have any time last night.
Quick office etc on KK
Hey Randy,
I know I keep using my old Note as comparison, but it is the only other Device I have working properly. So, I checked just now to see if quick office works. Yes, it does. It is able to read and write to the external SD card with no problem at all running KitKat. This tells me that OmniRom have cracked the issue of app permissions to write to the SD Card that Google kindly implemented without discussing with their user base. If Omni can do it I am sure you & Bob can work it out!! Good luck!
Rgds,
Colin.
Rgds,
Colin.
What I 've done : copy two files on my SD card from my PC (a xls and docx file)
Then open it with Quick Office and modify them and save with no problem.
On ES explorer, with explorer Root, I see that both /mnt/external_sd and /mnt/internal_sd have RW access.
So maybe, there is a difference in boot.img between M9Pro and M8HD
Originally posted by stevejc View PostHi, I'm testing Quick Office on my M8HD KitKat, don't have this problems.
Originally posted by colinabroad View PostThanks for this Steve at least it shows that the issue can be worked around. I just checked and I have RW access for everything on my M9Pro Quickoffice & Kinsoft office both crash and burn, only Office Suite is able to run - and it specifically tells me when I open a file on the SD card that it is ONLY read, not write. Are you able to try Office Suite to see what it does on the M8HD?
With Quick Office, it's OK. (no crash also)
The problem is due to KitKat and it depends on App
Try also Kingsoft Office : it crashes when it uses 'save file'
Originally posted by stevejc View PostWith Office Suite, external sd card is also read only can't write anything on it (new or modified files)
Trouble flashing
I followed the steps.. this is my first flash. everything goes ok, it erases nand and says successful. Then I try to flash the rom and it gets to writing data to flash, then says ERROR: download file failed ERROR: Run failed. I tried repeating steps and same thing happened. Can anyone help?
Sorry for the bad quality picture.. I tried taking screen shot on my computer, and resizing it to the allowable 185kb but it wouldn't work for some reason.. So I took a picture with my phone.
Erase NAND Properly
Originally posted by f0k4l View PostI followed the steps.. this is my first flash. everything goes ok, it erases nand and says successful. Then I try to flash the rom and it gets to writing data to flash, then says ERROR: download file failed ERROR: Run failed. I tried repeating steps and same thing happened. Can anyone help?
oops, did not see our last post about trying Pipo rom already!! Are you running the flash tools as an administrator??
Did you have the loader checked each time? The loader is crucial. Also a good USB connection is crucial.
Sent from my M6Pro using TapatalkRandy
There are currently 1732 users online. 1 members and 1731 guests.
