Pipo M9 Pro RileyROM 2.7 KitKat
    Originally posted by f0k4l View Post
    Ok.. sometimes it counts by 200's up to 400.. is this normal or is it supposed to count slower?
    Who knows what's normal?? mine tends to go up in jumps of about 700??
      That sounds like a bad USB connection. Make sure you are using the stock cable that came with the tablet. Try another port. Erasing idb must count all the way to the top number...otherwise it isn't erasing. That's also the reason why the download isn't completing. All else fails, try a different PC.
      Sent from my M6Pro using Tapatalk
      Randy
        I'm still looking into the Quickoffice problem.
        It works flawlessly on my M6 Pro...I need to test it on my M7 Pro...because I'm running this ROM on it. I will compare the two and try to find what's different.
        Randy
          Thanks Randy for letting us know. If you can resolve the writing to External SD card at the same time that would be brilliant
            This KitKat ROM is based on a new KitKat firmware dated 3/20/14. Thanks to Freaktab member Manao for contributing the link to this firmware.
            This ROM has all of the usual RileyROM features:
            Rooted
            Debloated
            Init.d support with Busybox commands
            English Default
            Google Play Store fixes
            Updated Google Apps
            2, 4, 6, 8 or 12gb user app space by selecting the desired parameter file
            Auto Install feature added for installing apk files on first boot from external SD
            TWRP recovery installed on first boot by Abdul_Pt
            Reboot app by Petrus
            New boot animation by me
            Latest revision of the First Time User's Guide
            Flash Tool by Finless
            All made with a variation of 900SuperSport's Freaktab Kitchen
            Please donate to support RileyROM's on Freaktab.
            Greetings,
            I've read mostly all this trhead and some questions remains to help deciding to upgrade to kitkat or not.
            I have PiPo M9 Pro 3G (I read this rom is fully compatible with 3G) with an old RileyRom :
            Android version 4.2.2
            Baseband version UNA
            Kernel version 3.0.36+ root@alex-System-Product-Name #371 Tue Nov 19 20:51:55 CST 2013
            Build Number rk30sdk-eng 4.2.2 JDQ39 eng.root.20131120.141257 test-keys
            It is certainly not the "fastest" ROM I've seen but that was the only ROM that support cifs.ko module (I really need this module working) among several ROMs I tested in 2013.
            So I would need your advice and feedback :
            1/ does this KitKat ROM support cifs.ko* ?
            2/ is there a special way for upgrading to KitKat from the RileyRom version I run ?
            3/ I have titanium backup (paid edition) , can you confirm the option to backup/restore that Riley gave in this thread can be applied to my case ?
            Regards,
            * If this ROM supports flowessly cifs.ko , be sure I'll donate for it !
              Originally posted by armspecial View Post
              it is very good rom,no any errors, you can add modem Power button and make a clear android or add your programs or do other things.
              https://drive.google.com/file/d/0B2_...RlZVNSck0/edit
              Where did you find this? Is it KitKat 4.4.2 and have you done any testing?
                In russian forum 4pda . Yes i know it is 4.4.2 and i Test it, works Great , GPS is working great and all functions too. Only i cant use this rom, because there is no menu Modem Power, and i dont know how to add it. If you can add this menu , it will be very good. .If you have Randy s rom build.prop file, please send, ill try to change it .
                  Well I said screw it and reformatted my PC, worked like a charm..flashed successful on first try
                  Sent from my M9pro using Tapatalk
                    Originally posted by sidh View Post
                    Greetings,
                    Regards,
                    Does someone can confirm if the latest Riley 's KitKat Rom embeds cifs.ko module , please ?
                    Regards,
                      Yes, it's in there.
                      Randy
                        dear randy,
                        sometimes i get a random reboot (hot boot) on my m9pro using rom 2.7.1
                        it happens once a day or two do you know about it?
                        PROUD owner of PiPO M9 Pro
                        PiPO P9 best tablet ever owned!!!
                        PiPO Tablet Freak and Flashaholic!
                          Yes, it's in there.
                          Great news,
                          In case where something goes wrong with 2.7.2 install , is it possible to reinstall my old rileyrom ("Build Number rk30sdk-eng 4.2.2 JDQ39 eng.root.20131120.141257 test-keys" )
                          Regards,
                            Just remember to follow the instructions for switching back to JB from KK. It's a sticky in the main Pipo forum.
                            Randy
                              Randy if i use other rom, and there isnt any button Power Modem, what file i must change to get it back ? can you help ? smb say me that it is build.prop. i change it, but nothing . can you give me your kit kat build .prop file ? Thanks.
                                Houston, we have a problem!
                                I wantted to fool around with the RR 2.7 before flashing with comming RR 2.7.3 and change Dalvic to Art. It did the apk upgrading . I then rebooted and it upgraded again. Then something happened and I needed to reboot it using the reboot apk. It got stuck there. I reseted using the back reset hole. Because of a previous encounter with a faulty charger, it goes in to charging mode when I turn it off or reset it. I have to long press the power button to boot it. However, after switching to ART, the power button is not responsive. Basicly, I have a tablet that is stuck in charging mode and I cannot turn it on without using the power button. I am not sure if it will boot to flash mode if I hard reset it with jumping some legs. Any suggestions are welcomed.
