Sent from my M9pro using Tapatalk
Pipo M9 Pro RileyROM 2.7 KitKat
I didn't have a 3G card in the slot and i have the Tablet always on Airplane Mode.
But modem power was on even with Airplane Mode ON.
I did the following:
1. Airplane Mode goes to OFF
2. Mobile Networks-Modem Power goes to OFF (it was ON)
3. Airplane Mode goes to ON (I think there is no difference any more).
rik-rk29-dataonly goes away and Deep Sleep start it's action!
I now have "rtc_hym8563" but i think that this is ok.
I will see if the battery gets empty fast with that.
GPS is working with this KK. That is 100% sureLast edited by kostas; 19 April 2014, 16:44.
battery drain
I too am suffering still from battery drain. No, i do not have sim card installed, yes,modem power is off, yes, i read all posts before jumping in with information. If I have missed something I would appreciate someone pointing it out to me without dissing me!
I am loosing about 1% power per hour, always have. Pipo need to address this serious problem that only seems to affect the versions with sim card. If Bob or Randy are able to find and fix first all power to them. This is now for me the ONLY issue with my tablet. It is not however stopping me, its just an annoyance having to keep it near a charger. Rgds. Colin.
Actually, there is a fix for that. A patch I was using in my ROM's until just recently that assists with battery drain and deep sleep, but drastically reduces 3G performance.
The file is libril-rk29-dataonly.so
Download
This file is located in system/lib
With a rooted explorer app, rename the existing file (or cut and paste it somewhere else) and copy this file in it's place and give it execute permissions. On reboot, you should see improved battery performance, but if you have a 3G version, you will have drops in your 3G coverage.Randy
Originally posted by rrileypm View PostActually, there is a fix for that. A patch I was using in my ROM's until just recently that assists with battery drain and deep sleep, but drastically reduces 3G performance.
Download
Colin, you've been out of the loop for a while...welcome back!!!!!!Randy
Originally posted by rrileypm View PostColin, you've been out of the loop for a while...welcome back!!!!!!
Did you add the tun.ko for openvpn, or was that Pipo actually responding to feedback?
So, I just installed the rk29 file and my first observation is that the phone signal icon is present but greyed out in the top notification bar. Telling me of course that the radio is on but not getting a signal [no card fitted] before changing the file the radio either defaulted to off, or was able to sense the presence of a card automatically. When I put my card in [power off please guys] before and powered on I got the android system update splash screen before it went to password screen, indicating it was doing something. The mobile symbol came on immediately and all worked wihout changing any settings. No problem with carrier [china mobile] and no problem with getting onto the internet using the card. One day I will try to see if I can make phone calls on it!
I will try again later with this new rk29 file to see how bad/different it is. But what have you done to get better battery life when tablet is sleeping? Have you just turned radio power down?? If the radio is actually switched off that should make no difference, but if the radio is not actually off then Pipo have some work to do! I will have a play around today and come back to you. Cheers for now,
Colin.
Hahaha!!!!
It's just magic, man.....
Actually, the modem power is supposed to go off while sleeping. A bunch of users complained about it, so I quit putting it in the ROM's...for now. Let me know if you see a difference.Randy
I will let you know what happens on my tab tomorrow.
Originally posted by colinabroad View PostI am loosing about 1% power per hour, always have.
Yesterday at 8 PM tablet was left with 98% battery in idle state, Wifi On - Always On only when connected, 3G Sim inserted with Data and Modem Power disabled.
Today (over 10 hours from now it will be 24 hours in idle state) I will post some pictures of the battery details.
Originally posted by andyy View PostThe problem with no labels under homescreen icons is still present. Do you all use 3rd party launcher that nobody is complaining about this?
Originally posted by kostas View PostI didn't have a 3G card in the slot and i have the Tablet always on Airplane Mode.
Riley might be worth comparing v2.6 to the rest you have released
In my case i have the 3G sim inserted all the time, i have only had to set it to airplane mode with other roms except for this and early rileyroms.
1. Untick Modem Power (its ON by default)
2. Set Airplane Mode ON
3. Check if the device is going to deep sleep, if not do what kostas posted above.
Thanks kostas!
Download
thanks Riley, and very nice boot screen.
Re: Pipo M9 Pro RileyROM 2.7 KitKat
Originally posted by Timpukka View PostClash of Clans didn´t work with ROM 2.7.2. I just tried. All in all, the ROM is great. If someone knows how to get to work it, please tell me. It´s much harder play with my S2 than PIPO M9Pro.
By the way, thanks for the great work
Enviado desde mi M9pro mediante Tapatalk
There are currently 1796 users online. 0 members and 1796 guests.
