Sorry to say , imidiate step to firmware and stuff as a tablet is not charge is in my opinion the wrong step and a bridge to far.
If you want to try someting .... try to find out if the power adapter is working,just take a simple volt meter and look what the adapter does.
Maybe the adapter is not working,and easy to purchase one in your area.
If you have no meter go and find in your area a electro store who can help you out.
If the battery was real bad the tablet would not work or empty very quickly.
With my background in mind I realy think of a hardware problem the adapter the power entry plug on the tablet or a bad wire connection inside the tablet,maybe in the hurry battery was not mounted correctly.
So my advise check the adapter first.
Further this is a new tablet so claim it if needed.
And a critical note : ok your tablet is not working as it should be its brand new ok this can happen so give the seller or factory the chance to help you to fix it or give refund ...before you think about the agressive way of approche.
Better for yourself too,however I can understand your problem.
To avoid this I paid a little more .....and both it in a shop nearbye so if someting like this occurs I know there is proffesional help nearbye.
Hope for you it will be solved soon.
