Pipo RK3288 Tablets: Discussion
    Do not forget to disable your tablet sending rapports to pipo disable under settings - security below on that page
      Originally posted by androider View Post
      Just disable it and do not think about it further,as I did.
      All brands have there specific isues even de €500.00 and up tablets do.
      I completely agree!
        rapports?
        Rapports???
        Do you mean Disable : Security > User Experience Program to OFF
        People who think they know everything are a great annoyance to those of us who do.
          Yez you hit the nail on the head my friend.
            About the problem that I had with some Swedish TV apps (SVT Play and UR Play). Ijust gave me sound with no picture. I managed to solve it by enabling the option called 'Force 4x MSAA' in Settings --> Developer Options --> Hardware Accelerated Rendering. It works without flash player app too. I could uninstall flash player since these apps seem to manage without it.
            I found this information about the option 'Force 4x MSAA':
            "With a high-end phone or tablet with great graphics performance and you play 3D games on it, there’s a way to make games look even better. Just go to the Developer Options screen and enable the Force 4x MSAA option. This requires more graphics power and will probably drain your battery a bit faster, but it will improve image quality in some games."
              Ok Jlunse very good you are a good contributer to this forum.
              Iám still looking for the right flash version,Iám not able to download it as all my equipment says
              Drive
              Het spijt ons. U heeft geen toegang tot dit document, omdat het niet voldoet aan onze Servicevoorwaarden.
              U vindt meer informatie over dit onderwerp in het Helpcentrum voor Google Drive.
              I will translate Goofle drive does not give permission to this document as it does not match our terms of service
              I get this on my other android device and on my windows vista desk top.
              So Iám not able to download the xda modifyed flash version.
                Sv: Pipo P1 and P8 tablets with RK3288
                Drive
                Google gives me the same message.
                Did you try to install the modified Flash Player using Dolphin browser? You find it in Dolphin's lab section.
                  Ok I will try that.
                  No i did true website xda developers and get the message I copied into my previous posting.
                  But not now after a day hard work I relax in my garden feeding the koi in my pond.
                  En brouwsing a little with my p1
                  Weather is nice and summers are short
                    Ok I will try that.
                    Yeaa, enjoy surfing on Pipo P1! This is a powerful tab and I'm really pleased with it.
                    Weather is awesome here in Sweden too ...30 degC and blue sky :-) !!! Life is good!
                      Dolphins lab section where to find.
                        Originally posted by jlunse View Post
                        I experinced the same but it works fine after disabeling multi window option in settings menu.
                        curious - where did you disable it?
                          Below where you set wifi
                              Thanks ,I found it flash works now,hope this version will work with boat brouwser as that is my favorite one.
                                You can try disabling developer option too, on some older tablets it improves performance: generally speaking on a NON experimental firmware version, developer options should be disabled.
                                Here in North of Italy there is a November wheater....It's rainy almost EVERY day... terrible!
                                So I could use the tablet as an umbrella here!!!
