Hi Guys,
Here is a link below to English release V1.0 2014528 ROM. No China apps installed.
The response in quotes is from Cube Australia , regarding some recent issues.
"I have a good news for you. Seems I have solved all the issues.
A bit background first
In Australia market, we have two rom versions, one is the V1.0 which is in your first tablet, and the other is v1.3 which is in your second tablet, technician just simply changed the v1.3 language into English.
Ok, your issues first:
1) Long time boot issue
The V1.0 is a stable version, the long boot issue might be caused by improper recovery by our technician due to different driver installed. So, just re-flash the romv1.0, and the issue should be solved. I have now upload a full firmware package, v1.0 20140528, onto Google Drive, path:https://drive.google.com/file/d/0B8u...it?usp=sharing
This package includes full drivers, rom(v1.0), SP flash tool(should have no difference with other MTK flash tools) and an English Operating Manual! You can now start to download it!
2) Customised v1.8 on your second tablet
All v1.3 Chinese version onward are customised to serve the Chinese market, they have certain bundle apps installed. It is not recommended to be used. Therefore I suggest you to flash it back to v1.0.
Now, issues on Freaktab forum
1) Cool ui v3 black screen issue
This should be caused by a) the missing file in the rom package, and most important reason b) the drivers. Please see my V1.0 package, in which there is a full package of drivers for MTK8392/6592 in Windows XP/Vista/Win7/Win8-32bit/64bit. Now, how to recovery the 'dead' tablet:
a) connect the tablet with your PC by USB cable
b) open 'Device Manager', there should be an 'unknown device' showed up
c) install the drivers for this device by selecting the RIGHT driver
d) the driver should now be installed and the device is shown in 'Port (COM and LPT)' and the device name might be 'MTK xxxx port'
e) now you can flash the device under the normal step......
f) finger crossed...
In conclusion
All the issues above are most likely due to wrong MTK driver installed. Once you installed the right driver on your computer, it should be OK to flash any rom. This can also explain why you cannot use flash tools at first time. Also, to all 9x users, we suggest you install v1.0 only at the moment. Once we have the later Official English version for 9x, I believe it should have, we will release it any let your guys know at first instance. Meanwhile, if you find any issue in using v1.0, please let us know, we will improve it.
Hope this can help.
Cheers,
Cube Australia
P.S. I double checked the package, there is a bit Chinese character in the folder name, you can delete it if you fell a bit annoy, shall have no impact on anything."
