Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
May be worth looking in settings, storage.900Supersport
freaktab developer
And the default write disk is set to ...
Sorry confused with another post. No other ideas at the moment sorry900Supersport
freaktab developer
Originally posted by 900supersport View PostMay be worth looking in settings, storage.
When i "move" an application with "Android assistant" for example, the only option i have, is to move the application to the "USB Storage", which is the build-in rom, not the SD card....
Any other idea ?
Thanks for your time.
I don't move apps to SD as I prefer to resize the system partition. I tend to use the external sdcard just for backups etc.
My guess would be that it may be connected to permissions as 4.4.2 revised permissions. I had to edit permissions so that tb could used the external sdcard.
Brian900Supersport
freaktab developer
Originally posted by 900supersport View PostI don't move apps to SD as I prefer to resize the system partition. I tend to use the external sdcard just for backups etc.
Brian
Thanks for the info.
I 'll keep an eye for the sdcard permissions update
I have the 32GB 9x tablet, so moving apps to "USB space" is not all that bad, but it will be nice to be able to move apps to SD card too....
One other option i think it would be really great in 9x, is the addition of an "Telephony hardware OFF switch", to save battery for those who does not need telephony futures on the tablet.
I switch my tablet to "Flight mode" to turn off telephony hardware, but it is not the best way....
Cheers
Sotiris
See post 1 for permissions fix900Supersport
freaktab developer
Originally posted by 900supersport View PostMy guess would be that it may be connected to permissions as 4.4.2 revised permissions. I had to edit permissions so that tb could used the external sdcard.
BrianOriginally posted by giouncino View PostAnother bad thing is that the cube is not able to read/write NTFS partitions. My older Pipo read everything without any issue.Originally posted by fokemon View PostYes. At least it shows me that there is an SD, and free space in nnn gb. But when trying to store there somehting, all programs say that sd card not found.
Picture that I took was saved to card, however
32GB SD Card is a no go with this tablet, to use formatted in Fat32 (file size limited to 4GB) is useless as i usually keep files larger than 4GB (3-4 movies in 720p).
Thank you!
Originally posted by Edius View PostMaybe you can fix problem with External SD card formatted in NTFS ?
Thank you!
This problem is already fixed by installing "Paragon exFAT, NTFS & HFS+" from Play store. You can even connect an external USB HD formated with NTFS with this app, provited you have enough power supply for the external HD.
Hope this helps you.
Sotiris
Sotiris
I'm thinking it could be fixed in next ROM release.
My Pipo M9Pro could read/write NTFS cards with KitKat .. no additional app needed for this.
Originally posted by KeFe View PostI have 20GB on internal and about 10GB on external so that should be enough
So... May I change the superuser app, or I will loose TB functionality again?
If yes then which superuser should I choose from play store?
Is there any possible way to sync my chrome bookmarks with a working browser until a chrome fix/kernel came out?
Missing daydream features also
Originally posted by jburkemx View PostFirst off, thank you very much for the rom.
I seem to be missing the default Photo Frame and Photo Table apps for the daydream functionality?
Does anybody know how I can get them back?
The screen shot below shows what I'm missing:
Using V1.0 2014528 stock , at the moment. What ROM is the screen shot from?
hi
Hello everyone
first sorry for my bad english.
i bought a Cube Talk 9x white 16GB with Verison: 1.8 and Andoid 4.4.2.
Now i have download the Software.
My Problem is:
When i shut down the Cube and connect it to my PC it disappears again and again ( looks like a loop or so ). The same as i disconnect the Cube every time. For a few second i can see the Battery Symbol in the Screen with a red X ( The Cube Battery is 90% ). Now i have open my Device Manager and install the driver after a long Journey. But the Problem still exist when i connect the Cube.
I can See in the Device manger that my device is connected for 1-2 sec and then it disappears. After a few Second the same ( loop)
I have take a other micro USB cable and on my Work again 5 deiffrent Cables but the Same problem.
I take my PC at Home, a laptop, and a Lenovo Tiny PC with nothing on it (Win 8.1 fresh Installation)with USB3.0 and power on the USB port but with all Cables the same Loop effect.
Have someone a Idea how i can install the ROM?
My last IDEA is to by a USB 3.0 HUB with a External Power Supply
(When i power on the Cube everything is fine. I can use the internal and Micsro SD Card with write access.)
Thanks for all
Lucky
connects then disconnects when charging symbol appears
My Problem is:
Thanks for all
Lucky
My U65GT does exactly the same thing.....but I am still able to use the SP flash tool and upgrade or downgrade ROM versions. Once the DA and scatter file are loaded , select the download option then connect the U65GT and works fine for me.
There are currently 2736 users online. 0 members and 2736 guests.
