Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Flash...
none of the flash browsers are good(firefox,dolphin) firefox crashes too often and dolphin doesn't go to all websites. Boat is pretty stable but flash is not working.
Originally posted by kukowontz View PostAt some point people will have to accept the fact that Flash is no longer officially supported. Since there will never be true fixes ...
This HD release is especilally built for tablets, but unfortunatly is reported as incompliant in the store and cannot be installed from there. But apk of all released are available in aptoide. I installed it from there.
It is not CM, it is called "UC Browser HD". I found it on aptoide. My felling is that it loads web pages much faster than the stock browser, and the tablets doesn't heat. I tried many other ones before this one.
Now I have set it as default, I will see with time if it is a good browser or not.
Originally posted by seb_131 View PostIt is not CM, it is called "UC Browser HD". I found it on aptoide. My felling is that it loads web pages much faster than the stock browser, and the tablets doesn't heat. I tried many other ones before this one.
su binaries should be updated
Originally posted by furonai View Post
please advice what i can do here.. with this message...I am on last Brian's ROM...
GPS hardware not working
Hi folks,
I run into a strange issue here.
I have 4 cube talk9x (U65GT) and i have install 900supersport's rooted 1.8V firmware and the 2 Lepi's patch extsdcardfix.zip and partition_6gGIG.zip for 6GB rom, two weeks ago. Today i noticed that hardware GPS is not working on any of those 4 tablets. I had never needed GPS all this time, so i do not know when GPS stopped working.... I tryied Google Map, Route66 and Sygic from play store, but no luck.
I have triple-check all the settings in the "location" and it should be working, but no joy.....
Any idea ? Anyone else with the same problem ?
Thank you.
I am in the same config as you. The GPS seemed to not work (no sat displayed in Sat config tools). I tried a lon gtime outdoor, and then it worked.
try this:
Originally posted by Lepi View PostPatch for CWM or TWRP for 4% min brightness
upd_CubeT9X_auto_bright_low10.zip
There are no guarantees! Preliminary backup is required!
Successful renovation!How do I install the brightness patch with CWM? CWM is installes on my device.
BTW: I did the last ROM update of superuser900, just need to try a little bit. I did the custom ROM update in this hour.
regards from germany
Originally posted by netnoise View Postl know it is a absolutely noob question, but I am a noob at this pointHow do I install the brightness patch with CWM? CWM is installes on my device.
It work with original recovery of talk9x-non-root tablet.
Download and place the update.zip at sdcard(internalSD),then follow this.
There are currently 2935 users online. 3 members and 2932 guests.
