Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Best advice would be to try a different power supply.900Supersport
freaktab developer
i think it wouldn't help, i'm using a 2.1A Belkin charger and stock Cube cable, it just drained too much, because of battery indicator bug. i could still try stock cube charger and even shorter cable.samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by pärkkälä View Posti think it wouldn't help, i'm using a 2.1A Belkin charger and stock Cube cable, it just drained too much, because of battery indicator bug. i could still try stock cube charger and even shorter cable.
If it is fully discharged, it might take some time before the battery has a minimum load to indicate the charging process.
it's totally empty, i let it to charger for 20min, and battery was drained more. it didn't have the power even to show the charging icon. that means it didn't charge at all. Normally it starts to show battery percentage and blue charging battery icon, now it was stuck to the first icon, a red battery with lightning inside.samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
I generally use the cube untill it automatically switch off (0% battery left).
Then I leave it charging for 7 hours and it show 100% complete battery charge.
I changed the stock USB cable (not good for me) with the one coming from my western digital external USB hard drive that works a lot better.
Never had ANY issue on charging from 0%if you appreciate my efforts this is the link for any donation:
Originally posted by pärkkälä View Postmy cube's battery wont start charging after it drained empty. can i do something for it?
Mine was a 32GB version, not sure if it makes a difference, hoping it was just a random fault, and not an indication of something deeper within the components.
Atrak
This happened to the moto G and could be fixed by letting it charge for more than 24 hours... Then, the battery started charging and you could turn on the phone... Since the cubes battery is a lot bigger than the moto g's, maybe you should wait even more...
If it doesn't work, you could always desolder the battery and charge it directly using wires...
Positive from power source with positive wire/contact from battery and negative from power source with negative from battery... To make a power source, just use you regular charger and cut a USB cable (use red and black wires as positive and negative sources)
Leave it charging for an hour... Monitor the battery to make sure it's not overheating (because of a short circuit or bad contacts) and it should at least charge enough to be able to power the tab again...
Originally posted by eteles View PostThis happened to the moto G and could be fixed by letting it charge for more than 24 hours... Then, the battery started charging and you could turn on the phone... Since the cubes battery is a lot bigger than the moto g's, maybe you should wait even more...
The display shows the loading pic just for a few seconds then display shut down for faster charging.
If the Battery is to low, the display shows nothing. Normally
But it charges anyway...
Slow, but it does with the common 2A charger...
Better would be a bigger charger...
If battery drains down to 0 you need a lot of power to reanimate the battery.
I figured out with my Galaxy Note (2A) Charger from 0% of power...
It needs more than a hour, till the tablet recognize that's there is a charger connected
With my 4A (some called it SUPER-)Charger it needs up to 5 minutes till I get a reaction from my cube when power drains down to 0%
My CUBE works fine with that 4A Charger without any faults since 2 month or so...
Anyway...
My Question is:
Is there a way to play a sound if I connect my power to Tablet like my Note2 does?
I would like 2 have a sound like "doodub" if I plug the power in...
Every sound would be fine!
When I'm using the wrong cable (it could be, especially from my Bluetooth Speakers) the Tablet won't charge...
But I plug in and go to bed...
Next morning Tablet is off @ 0% cause I didn't realize that's those cable won't charge...
Any sugesstions, please?Last edited by Spassknochen; 23 October 2014, 20:49.Sent from my U65GT via chrome
Originally posted by 900supersport View PostBest advice would be to try a different power supply.
I've tried it with my Note 2 charger (2A) when tablet was drained down to 0% and it needs over ONE hour that CUBE recognize that there is a charger plugged in...
With my 4A charger it takes just 5 minutes to activate the CUBE again...
Now I'm asking again:
Is there a way to play a sound if I plug in my micro-USB like my Note 2 does?
Thanks 4 any suggestions...Sent from my U65GT via chrome
Installing drivers on Windows 7
I've tried to install the drivers on Windows 7, using the drivers provided.
But without full success.
Whenever I connect the Cube Talk 9X, W looks for drivers and ends up telling me that the device is disconnected.
I'm not sure what to do with the drivers provided with the rom.
Can someone describe precisely what I should do to install the drivers?
Thanks in advance,
Originally posted by enay View PostI've tried to install the drivers on Windows 7, using the drivers provided.
Thanks in advance,
Some programs like e.g. daemon tools can block your drivers and a succsessful flash...
For most of the people here it works fine, 'cause their have a well working Win...
If the drivers won't work you have to give more information...Sent from my U65GT via chrome
With tasker you can add almost everything to do automatically on almost every event.
When I connect my cube to AC power it says now 'charging' and switches off some useless things during that period.
There are currently 1753 users online. 0 members and 1753 guests.
