Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by ludoke View PostI did it that way.
Originally posted by eteles View PostThe driver that should be installed is the MTK preloader driver... I have not succeeded installing it on win 8 x64 (even disabling driver signature verification), but it works fine with windows 7 x64...
i had some problems with it, the device appeared only for 10-20 sec, but i installed the drivers during that 20sec and it worked. win7 ultimate 64bit.samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Originally posted by ludoke View PostAlso tried this, nothing.
This post on xda-developers might help, though. Or this one. The consensus seems to be that the problems are associated with enforced driver signing on windows 8.
I used windows 8.1 x64, with limited problems for driver installation.
Now everything is working fine.if you appreciate my efforts this is the link for any donation:
i have now issues too, on the first ss900 1.8 it was working, now with newer version it stucks sometimes. it doesn't stuck if you use the whole battery everyday and charge every night. if battery lasts for a week for example, it's stuck when you start using it next time.samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Originally posted by eteles View PostMy magnet case has just arrived and I'm experiencing the battery percentage bug... After using case with sleep function, the battery won't display the correct charge... It only displays 99% even after more than 1 hour of use...
Is there a fix for this??
Before that (without case) how was your battery percentage displayed?
I have an identical case and experiencing same bug (September ROM)
@Edius Yes... This is a bug caused by the sleep/wake feature from the cases with magnet... Before using the magnet case, the battery was displayed correctly always...
This was already addressed by several users before me... Just don't know if they found a fix...
Anyway, after using the tab a few more hours, the battery dropped fast to the correct value and now seems to be showing the correct percentage... Self fixed...
my cube's battery wont start charging after it drained empty. can i do something for it?samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
There are currently 2571 users online. 2 members and 2569 guests.
