Now I am with Brian's rom and Lepi's TWRP. I have only great difficulties with external SD and ES Explorer which can't write on it thow internal explorer can ! While creating a folder, ES Explorer says it will create folder asynchonus or something like ...
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by alattack View Post
Now I am with Brian's rom and Lepi's TWRP. I have only great difficulties with external SD and ES Explorer which can't write on it thow internal explorer can ! While creating a folder, ES Explorer says it will create folder asynchonus or something like ...Cube U65GT Talk9X 32go
Brian's rom and Lepi's white TWRP
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by alattack View PostI assumed that the recovery_orig is Cube's.
I tried to flash Brian's ROM yesterday, but I'm stuck with drivers installation. I can't install drivers when I plug the tablet. Been trying to install manually then but with no success. It seems that the drivers in the X86 folder are X64 versions (or at least my windows thinks so).
I'm on win 7 SP1 (X86): any idea how to install the drivers without problems? I know some people faced the same problems and succeeded to install the drivers!
Now disconnect Cube, make all ssettings in SP flash tool, click download and connect Cube again - flash will start.
ntfs not supported even with paragon
[QUOTE=valerima;218788]Originally posted by valerima View Postdears,
cannot copy in .mkv movies bigger than 2 gb to tablet or sd card -64 gb.
format= fat 32.
do you know how to solve it...
Is ntfs supported?[/QUOTE
sorry=resolved.]
joy was too early, even paragon does not help with ntfs formatted sd card.
shit.
Originally posted by dragan76 View PostHi Brian. In docs you dont have recovery_rua1_CWM.img. Only recovery.img and recovery_orig.img?
Sent from my GT-I9505 using Tapatalk900Supersport
freaktab developer
format= fat 32.
sorry=resolved.]Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by alattack View PostSame problem here:
I have a white 16Go model running on stock 1.6 firmware (only rooted with mmrrdd method + downloaded a SDcard fix from Google playstore): neither valerima's method nor mmrrdd's method works for me.
-> Using android terminal emulator I have a permission problem on the SDcard
-> and using mobile uncle tools: can't find SDcard.
I guess this is a systems permission problem, but I don't know where to look. If anyone has an idea, feel free to give your input !
I can backup with TB on my SDCard 32go
I can backup my IMEI with Myuncle Tools
So everything is OK for the moment !Cube U65GT Talk9X 32go
Hello, I have the same problem... I want to back up my Imei but I can't!! How you solve this?? Please can you tell me the way?
Originally posted by antonis86 View PostHello, I have the same problem... I want to back up my Imei but I can't!! How you solve this?? Please can you tell me the way?
This is concatenation of several posts :
1 you must be root
2 open /system/etc/permissions/platformxml
3 change the permission name="android.permission.WRITE_MEDIA_STORAGE"> section to include
<group gid="sdcard_all"/>
4 go to market and load "SDFix KitKat Writable MicroSD"
5 run, give access root and apply ...
6 reboot
7 Load MyOncle Tools and Backup IMEI on SDCARD
And that was all for me.
Hope it will be useful for you.Cube U65GT Talk9X 32go
Originally posted by hawky View PostWell I don't say it's THE solution, but it works for me, for fat 32 SDCARD.
1 you must be root
6 reboot
Hi, All...
...I'm a very satisfied owner of a Cube (32GB, Black, firmware v1.8 from the start.)
I've had it for a couple of weeks now, and been reading this Brian's thread - and related ones - for as long. However, I couldn't register and post before now because, somehow, the registration image puzzle was playing tricks on me on my tab, lol, so I ended doing it on a laptop.
Like others have experienced, the Cube has been a superb machine. Brian's (@900supersport) ROMs have made life so easy for me on the tab (the clear instructions, initial rooting, the smoothness, and so on.) The latest one (based on 0806,) has been smooth as silk, and I'm enjoying the "Easter egg" that's been introduced into the boot animation...thanks Brian!
Another resource of particular note for me, is Lepi's screen brightness patch - so useful. Thank you very much, @Lepi.
Now, also as experienced by some, drivers for the Cube appeared not to have been successfully loaded on my Win8, 32-bit machine, no matter how hard I tried, but I'm able to flash too on the machine anyways.
So it's been all good for me with the Cube, and I doff my hat to all those that have helped, particularly on this thread.
I certainly I'm sticking around.
P34c3
Nice to have helped.900Supersport
freaktab developer
Originally posted by duwdu View PostAnother resource of particular note for me, is Lepi's screen brightness patch - so useful. Thank you very much, @Lepi.
Originally posted by mmrrdd View PostYou can root talk 9X with the original recovery,no need PC,no need driver.
download file "root_talk9x.rar",
http://www.4shared.com/rar/p9jdW35Xba/root_talk9x.html
extract, and place the update.zip at sdcard(internalSD),then follow this.
There are currently 2452 users online. 0 members and 2452 guests.
