Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
^^^ that brightness patch is working for my black 32gbsamsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Originally posted by hairydog View PostYou can sync your chrome bookmarks to any computer running chrome. Then you can use xmarks to sync them to just about any browser. Unfortunately, I think xmarks is expensive on Androidsamsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Originally posted by pärkkälä View Post^^^ that brightness patch is working for my black 32gb
Originally posted by mmrrdd View PostWhat model of your dead touch tablet,32GB or 16GB ?
Originally posted by Lepi View PostRegardless of the amount of memory, but only for firmware version 1.8samsung note 3 n9005 snapdragon [email protected] GHz|cube u65gt talk9x
Originally posted by pärkkälä View Posti'm currently running 900supersport's rom. the brightness is now much better to watch at night, and battery life does extend too, thanks Lepi for this!
dead gyroscope?
[ context: 32gb black ; this thread's rom ]
auto-rotation worked in the beginning but after some apps (Document viewer and/or FBReader) forced a specific orientation it isn't working anymore. I'm no even able to play racing games that depends on the orientation to steer.
Does anyone have any idea why and how to fix it ? rebooting doesn't fix it
Originally posted by dragan76 View PostCan anyone confirm that this working on 32gb black?
One more question: I have some strange icons on tablet - they have some borders on different colours. Is it possible to get icons like for example on Samsung s4
Tnx
you can change the layout and the icons style just by installing another Launcher (Apex, Nova, ...). I am using Apex (it's free on the PlayStore and doesn't require root : https://play.google.com/store/apps/d...launcher&hl=en ). It has a lot a customizing options, and a lot of skins are also available on the store (I use the default one, in Tablet mode, so it looks like the Samsung)
Originally posted by SV1JRT View PostHello 900supersport, I have already changed the "Default write Disk" option to the "SD card" but still no joy...
When i "move" an application with "Android assistant" for example, the only option i have, is to move the application to the "USB Storage", which is the build-in rom, not the SD card....
Any other idea ?
Thanks for your time.
Google has introduces several limitations since 4.3, and especially in Kikat :
- External SD card is not in write acces by default (it could be changed thanks to several apps, but which require root)
- it is not possible anymore to use an external SD to store apps data (if you set in the options the external SD by default, it will just store your camera pictures). You need to move your applications with FolderMount or Link2SD (or to swap your SD cards)
- Flash Player is not supported (Google has the same policy than Apple against Adobe Flash). To restore Flash, you should install a modified apk from Xda and use Dolphin browser
- The file structure has changed a lot. For example, the mouting file is hidden in the boot img and cannot be edited simply with a text editor
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
I'm still afraid to put 900supersport rom because of problem that some had with touch so i'm on stock. Of course that the problem of touch is not in that rom but....
Sent from my GT-I9505 using Tapatalk
Originally posted by otto8 View Postnew official rom V1.8 (20140806) http://pan.baidu.com/s/1kTICPYf
There are currently 1282 users online. 2 members and 1280 guests.
