from where?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
900Supersport
freaktab developer
All the stock firmwares I have seen for the u65gt have play store.900Supersport
freaktab developer
Originally posted by 900supersport View Post
TB give not enough space messages to the internal and external too.
Ultimate backup doesn't work also.
Did you apply it from recovery? Have you checked
If you have!e root?900Supersport
freaktab developer
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by dragan76 View PostSorry. Too exited that i didnt see. Mine arrived with 1.8 rom. Do you suggest to flash with yours from first post or it is enough to put those 2 files to root and to erase chineese apps?
Sent from my GT-I9505 using Tapatalk
Once you have the drivers set up flashing is easy and gives a little more.900Supersport
freaktab developer
Originally posted by 900supersport View PostDid you apply it from recovery? Have you checked
If you have!e root?
SuperSU 2.02 appear in the app list after reboot, root checker give a positive result on root, but none of the backup aps can save or restore any application data.
I tried TB, Ultimate backup, MyBackup pro without succes. Internal and external sd also.
update zip 236mb?
Update failed , android lying on his back with exclamation bursting from his innards.
Any ideas.....
Root failure. Also the file shows as 236mb?
Originally posted by mmrrdd View PostYou can root talk 9X by original recovery,no need PC,no need driver.
download file "root_talk9x.rar",
http://www.4shared.com/rar/p9jdW35Xba/root_talk9x.html
extract, and place the update.zip at sdcard(internalSD),then follow this.
Odd, I have no problems with tb pro. How much free space do you have?900Supersport
freaktab developer
Originally posted by dragan76 View PostNot recognize from win8. I saw that a lot of people have problem with cable.
Sent from my GT-I9505 using Tapatalk900Supersport
freaktab developer
Hello 900Supersport and Lepi,
Thank you both for a GREAT work done.
One small question.
Although everything is working great in my 9X, when i try to move an app to the SD card it forces me to move it to the USB storage instead of the SD card. My 32GB SD card is virtually blank. (only some mp3 i had copied from my PC exist in the SD card).
Any workaround on this issue or am i missing something here ??
Thank you all for your support.
Keep up the good work.
There are currently 3069 users online. 1 members and 3068 guests.
