Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
IMEI Backup
Originally posted by mmrrdd View PostCube U65GT Talk9X 32go
Brian's rom and Lepi's white TWRP
Originally posted by hawky View PostWell I downloaded MobileUncle Tools and when I want to backup my IMEI my sd cards are not found and it's impossible to backup anywhere !!! GRRROriginally posted by mmrrdd View PostOriginally posted by valerima View Post
I have a white 16Go model running on stock 1.6 firmware (only rooted with mmrrdd method + downloaded a SDcard fix from Google playstore): neither valerima's method nor mmrrdd's method works for me.
-> Using android terminal emulator I have a permission problem on the SDcard
-> and using mobile uncle tools: can't find SDcard.
I guess this is a systems permission problem, but I don't know where to look. If anyone has an idea, feel free to give your input !
TWRP install ?
Originally posted by 900supersport View PostHere's a lightly reworked ROM based on Cube's U65GT V1.8 firmware of 04 July 2014.
ROM Download
So what do you get?- UK English by default
- Root
- Removal of Chinese apps
- init.d support with busybox integration
- option of CWM recovery built with rua1's MTK Droid Root Tool, also included is Lepi's TWRP recoveries
- auto install feature:- if you create an autoinstall folder on your sdcard containing any default apks they will install on first boot. I tend to be sparing in this just loading my preferred file browser, terminal emulator and titanium backup.
I've included instructions within the download for flashing both the full ROM (required if you are changing from Cube's earlier firmware) or flashing just boot and system (ANDROID).
Hope this is of some use.
Brian
PS Lepi pointed out to me that its easy to boot into recovery as follows. First power off the U65GT, it vibrates when shut down completes. Press and hold power for about a second then press and hold vol+ until a menu displays (its small in white). Scroll through the menu options with vol+ and select with vol-
CWM zip fix for read only external sd card. Download and put onto the sdcard (internal or external), reboot to recovery and update.
[ATTACH]7000[/ATTACH]
CWM zip for 6 Gig apps space
[ATTACH]7001[/ATTACH]
Lepi has uploaded an updateda TWRP Recovery links in the following quote
i am very new with this
how can i install twrp on my cube talk x9? On their site (http://www.teamw.in/project/twrp2) i cannot find the Cube Talk X9 as being supported bij them.
Thanks in advance
best regards
Bertus
see post 1900Supersport
freaktab developer
Pushed for time so cannot make a proper post but I've added a link to post one for my reworked 1.8 of the 20140806 ROM.900Supersport
freaktab developer
Completely root ?
Is this an explanation ?Cube U65GT Talk9X 32go
Originally posted by hawky View PostI used Root Checker and saw that SuperUser is not activated !
SuperUser is installed on mine, both TiBackup and root checker are confirming that the tablet is rooted & SuperUser is activated.
Don't seems to be the source of the problem on mine, but due to that impossibility to save the nvram file I don't want to rush flashing a new ROM.
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by 900supersport View PostPushed for time so cannot make a proper post but I've added a link to post one for my reworked 1.8 of the 20140806 ROM.
Sent from my GT-I9505 using Tapatalk
Brian ...
I just downloaded your ROM for my soon to be here Talk 9X. I applaud you for what looks to be simple and concise instructions. Thanks.
One question.
What is the difference between the 'ROM Download ' & 'ROM Download update from 6 Aug ' ?
I downloaded the Aug.6 version, but just wondering why the original is still listed? Usually the newest version is all anyone wants.
Thanks again. I look forward to this new adventure in the land of CUBE! Been a Pipo fan for a long time !
Drinking the new coolaid!
Last edited by BamaPanda; 24 August 2014, 04:18.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by dragan76 View PostHi Brian. In docs you dont have recovery_rua1_CWM.img. Only recovery.img and recovery_orig.img?
I tried to flash Brian's ROM yesterday, but I'm stuck with drivers installation. I can't install drivers when I plug the tablet. Been trying to install manually then but with no success. It seems that the drivers in the X86 folder are X64 versions (or at least my windows thinks so).
I'm on win 7 SP1 (X86): any idea how to install the drivers without problems? I know some people faced the same problems and succeeded to install the drivers!
There are currently 1787 users online. 0 members and 1787 guests.
