I will test it today or tomorrow on my Pipo P4 too.
Pipo P4 RileyROM 2.0
link: https://mega.nz/#!WAhWHSaJ
password encrypt: !W3dRwlaASwp-uwHLbC4zsd3_aHmCZ5BHgpX5pJ0RSD4
great, will give it a try too, I'm currently on 5.1.1 kernel is based on that release...Ultra U8 owner
Freaktab fan and PiPO Tablets PH member
https://www.facebook.com/groups/pipotabletsph/
Here is the Firmware on Mega:
http://tinyurl.com/pipop4loli
I hope Riley can make a cool Mod out of this
Edit: Miguelo210 was faster
Originally posted by Jakwow... at last, a very bright but late future for us... Hoping and praying for Riley's hands on this.
@minabuba
Is everything working? Btooth, HDMI?
Is the kernel finally unlocked to 1.8ghz?
Hdmi, Wifi and bluetooth any problem.
Enviado desde mi MI 4 mediante Tapatalk
Originally posted by Jak View Postwow... at last, a very bright but late future for us... Hoping and praying for Riley's hands on this.
@minabuba
Version ist for the 3G and Wifi Version so you have a signal bar even if you have only wifi.
Xposed doesn't work for me (bootloop). And I cant get rid of the stupid kingroot and kinguser that is preinstalled. twrp works.
Apps ect. work fine. Stable so far.
No 1.8 Ghz but faster (due too Android 5.1 and new GPU drivers...even a tool from Rockchip is included to update the GPU Drivers).
Thats all so far.
Chinese rom by xy works so far the best 5.1.1out there for P4 (there is a cm 12.1 and another 5.1.1 for P9 which can be used for P4 by replacing Kernel from 201501009), they say it is based on a beta release 5.1 rom for P4 last september p4-5.1-201501009? not sure if true but it is good,
Can someone check if this is the official 5.1.1 by Pipo, can't check it , I dont know how to download from baidu ...
http://pan.baidu.com/wap/link?uk=250...028268&third=0
And some roms here too
Here's my test so far XuanEdge rom based on p4-5.1-201501009
Tested working:
*Auto-rotate works perfectly
*Camera works with led flash working too, autofocus seems a little weaker, and shutter button layout is at the top in portrait, should be below..
*Mic works
*Headphones work properly
*Wifi and works
*OTG works
*HDMI works! but screen zooming is weird on my tablet when you try to slide to adjust the screen fit on an ext. dispaly it's the tablets dispaly that zooms in and out not the ext. monitor/display lol
*Facebook and Youtube video works no display/sound issues
*Mx player works
*TWRP works (5.1)
*was able to replace KingUser with SuperSU/SuperUser using update zip via twrp , I've already uninstall it and delete its apk in the system but it still gives an on screen message from time to time, somewhat annoying when your playing games or watching video as it will minimize whatever app your using
*Very smooth UI antutu is 37500
*Not sure if Xposed is working I haven't tried yet, I think it needs lolipop xposed framework for sdk22 flashed via recovery/twrp and xposed installer 3.0+, will test later...
Some issues still present:
*Auto Brightness works but touch response have delays and some ghost touch issues when enabled, and will like not response to touch anymore when you try to lock and unlock the tablet...
*HDMI screen zooming (adjust the screen fit on an ext. dispaly it's the tablets dispaly that zooms in and out not the ext. monitor/display weird..)
It's still locked at 1.6ghz cpu and 500mhz gpu they still won't let us taste the advertised 1.8ghz though I think the difference won't be much cpu side but gpu on 600-650 is way better...
Still checking for more but so far it is very good, alot faster than 4.4...
~would love to have it 6gb internal and swapped Nand and external SD~
Thanks!Last edited by jastaz23; 10-23-2015, 11:37.Ultra U8 owner
I can't get xposed to work too, I tried flashing frame work in recovery (xposed-v75-sdk22-arm.zip) boots up to optimising apps but has an error message going to home screen like "unfortunately process.android.phone has stopped" something like that so I just uninstalled it in twrp ( xposed-uninstaller-20150831-arm.zip) and wipe dalvik/cache and I'ts good again...
links for installer and unistaller in case you wanna try...
Ultra U8 owner
There are currently 2439 users online. 3 members and 2436 guests.
