Sent from my m7pro
Pipo P4 RileyROM 2.0
The correct method is to flash the whole ROM first with the stock recovery. After the first boot process is complete, uncheck all of the other ROM components and flash TWRP alone.
Sent from my m7proRandy
Originally posted by alexn View PostI had already upgraded my P4 to RileyROM 2.0. Can I flash this Recovery alone ? Or I have to flash RileyROM 2.0 with TWRP recovery together ?
As luck would have it, I received my test P4 today and immediately flash this ROM to it.
The ROM seems to work quite well!!!!!
Unfortunately, I can't get TWRP to work. I tried repacking the TWRP image with the current stock recovery components, but it still won't boot. So if any of you have been unsuccessful in getting TWRP to run...it isn't that you are doing anything wrong...this version of TWRP still needs to be fixed.
Stay tuned for a fix, hopefully soon.Randy
You lost your passwords...when?
Was it after a reboot?
Each time you flash a ROM, you will have to enter all of your passwords again.Randy
Originally posted by rrileypm View PostAs luck would have it, I received my test P4 today and immediately flash this ROM to it.
Is it preformed well out of your expectation ?
We would like to see some comments or a review from a ROM developer's angle.
Re: Pipo P4 RileyROM 2.0
Sent from Tapatalk on my Pipo P4 running RR 2.01
Originally posted by pauw176 View Postthe flashing is gone fine , then all passwords entered, but if I push on reboot I only re-enter my password for the wifi. And all the icons have disappeared alongside the home button
Sent from my P1 using TapatalkRandy
Originally posted by alexn View PostRandy, will you share your comments or write a review about P4 ?
One thing to try is using a different parameter file.
Which one have you flashed?
Originally posted by pauw176 View Postthe tablet is running with Dalvik.
There are currently 1177 users online. 1 members and 1176 guests.
