Pipo P4 RileyROM 2.0
    Hello!
    I just received a brand new P4. I started it, ran Antutu and it works just fine.
    To make a long story short, I accidentally flashed it with P1 firmware
    Now it wont start.
    Is there a way to flash it again or is it bricked?
    A software improvement for "AndroidTool.exe" would be when clicking to open the file browser, the default/startup path should be from where the exec is located and not from history from when it was last used (from when I flashed my P1 in my case)
      SAVED
      I was able to start the tablet with a combination of the buttons vol+ and power. Successfully flashed it and now it is running ..... wont make that mistake again
        As luck would have it, I received my test P4 today and immediately flash this ROM to it.
        The ROM seems to work quite well!!!!!
        Unfortunately, I can't get TWRP to work. I tried repacking the TWRP image with the current stock recovery components, but it still won't boot. So if any of you have been unsuccessful in getting TWRP to run...it isn't that you are doing anything wrong...this version of TWRP still needs to be fixed.
        Stay tuned for a fix, hopefully soon.
        Hi Randy, what is the status of getting TWRP to work ?
          I haven't gotten back to it. After I tested it on mine...and it didn't work...others reported that it did work for them.
          Randy
            Hi.
            This is my first post and wish to thank you for the RileyROM 2.1.
            Just received my P4 today and needed to flash it as for some reason it didn't come rooted and Titanium Backup would not run. Had a little problem with installing drivers in Win7 x64 and ended up having to use the Driver Assistant (DriverInstall.exe). I then had to click update driver in Device Manager and after that all went well. Probably that was because I previously had flashed my M7 pro and had older drivers installed.
            On thing I have noticed is that the stock ROM Antutu benchmark was around 39000 and with this ROM its 34144. Slight drop but so far it all seems to be running well and a donation will follow..
            Will keep you posted on battery drain.
            Edit: PS Where do I find a donation link?
              Just click the donate link in my signature. Thanks for the feedback.
              I'm just waiting on another firmware update from Pipo...hopefully soon.
              Randy
                Cheers, didn't know I could click on it..now done.
                  Your donation is greatly appreciated. I'll make sure it goes to good use...furthering my ROM development.
                  With everyone's donations, I was able to purchase a P4 to test on.
                  BTW...has anyone heard of or seen a P4R tablet? I've seen some firmware updates for this tablet...but I don't know much about it. I guess it's an updated model.
                  If you own a P4R...DO NOT FLASH THIS ROM!!!!!!! Just ask me, and I'll make a new ROM just for the P4R. I'll wait on a request...no sense in doing a ROM yet...until I know there's a demand for it.
                  Randy
                    Just wonder, if there will be a firmware update for P4 soon ?
                      wondering the same as the 3288 hph box is getting lots of attention from Mo..... cheers riley
                        As of today there isn't a newer firmware available from Pipo. I will post a new ROM when I receive a firmware update. Currently #665 is the latest.
                        Randy
                          so i just had contact with someone from pipo and they dont have a model in their company that is called the P4R
                          but they also dont know if it should work on the P4 ...
                            Could be one revisión of Last firmware of p4?? Sorry for my english. I Know one user Who instaled the rom on p4, and run perfectly.
                              What are the different parameter files for?
                              I often have lagspikes and reboots on my P4 with 2.0.1....
                              Running it on ART.
                                Re: Pipo P4 RileyROM 2.0
                                Running it on ART.
                                The parameter files are for choosing the size of the system partition in case you're a big app installer. I always use 4Gb and am only at 60%.
                                I very rarely have crashes on my P4 but not using Dalvik.
                                Sent from Tapatalk on my Pipo P4 running RR 2.01
