Pipo P4 RileyROM 2.0
Finally,I'm having a fantastic time with this rom.
Here's what I did:
1. Installed the rom with the fixed TWRP
2. TWRP, wiped cache and dalvik (now I know how important TWRP is)
3. Reboot after the first boot.
4. Installed a Batt Calibrating app and calibrate. And Charged it full for more than 3hours.
5. Drained the batt to shutdown with some 3d games.
6. Recharge again.
Now everything is running as it should be, No sudden batt drains, no sleep of death, and the UI is much better.
Looking at the details of this rom's kernel, I think this rom is using the P4R kernel, is it?M8pro
M9pro (current tab)
It appears there are no more firmware updates past this one for the P4. So, I'm afraid there isn't anything new to report or produce.Randy
Wishful thinking of a good news... since, well, their FB page is a bit alive.
Btw, does anyone here has any solution for my Asphalt 8: Airborne problem? Tried to the lowest graphic option and the problem persists. On NBA 2k15 P4 FC's.
Here's a screen cap of Airborne problem. And yes, though blind, I managed to win... milagro does happen. Help please.You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosM8pro
M9pro (current tab)
Originally posted by Jak View Postdon''t use chrome browser for flash videos. On UC browser I'm not encountering that problem.
Hey All,
Unfortunately I made a brick from my P4 table
It happened when I did an upgrade (it was not my first upgrade)
the from state of the upgrade was an OMA rom. I was curious how is an OMA rom is working
Not bad, but the latest Riley 2.0.1 is looks better so I wanted to go back.
The following are done:
- started the AndroidTool.exe
- Switched to Flash mode (Switch button)
- Erase the IDB, LowerFormat button
- When it finished (Lower formatting) I clicked on the Run. but the first file transfer is failed
(I suppose the used usb port could be the guilty or the used usb cable)
the AndroidTool cannot see the P4 any more.
- is there any recovery precess?
- if I can turn the P4 to flash mode manually (using some combination of external buttons ) would it be useable? what is the way to switch it to flash mode manually?
Thanks for any help in advance
Best Regards
Istvan
connect it again to your pc and open the flash tool then try hold pressing/press hold both power and reset button (little hole at the back of your P4 with a pin or something that fits) wait till it says connected (or something that goes green on the flash tool, I forgot already lol ), if that doesn't work, I remember reading a thread here about shorting pins inside the tab.... GL.Ultra U8 owner
Freaktab fan and PiPO Tablets PH member
https://www.facebook.com/groups/pipotabletsph/
I am having trouble with my p4 recently. I am getting garbled text and graphics in chrome and a game like roller coaster tycoon. I tried wiping my data but it had no effect. Would a full wipe with the PC work?anyone else have the same issues? Screenshots attached.
Additional update. Just flashed latest ROM again, added twrp and wiped cache and dalvik, no effect. Could this be a hardware issue?You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by locutus2000; 21 August 2015, 09:06.
There are currently 2123 users online. 2 members and 2121 guests.
