Pipo P4 RileyROM 2.0
Are the crashes happening with the same app? There are some apps that still aren't ART compatible, or have trouble running in ART.Randy
Originally posted by rrileypm View PostAre the crashes happening with the same app? There are some apps that still aren't ART compatible, or have trouble running in ART.
You think this is due to usage of the ART runtime?
-edit-
For example... Google Chrome app is slow and often unresponsive on my Pipo P4... but fine on my Nexus 5 phone.
I would try switching off ART and see if that helps with the crashing issue.Randy
Originally posted by stervis View PostHey, just another question.
I've noticed Cell Standby taking up a lot of battery, but this is the Wi-Fi only tablet so far as I know..
When I turn off Data Enabled and Data Roaming under Mobile Network Settings will solve this 'problem', right?
Multiuser
Hi everyone,
Thanks by the ROM. I already installed this (2.0.1) with no problems in a friend's Pipo P4 who wants a custom ROM.
My problems is that he wants Multiuser options but I can't understand how activate it. if there is any how-to I would appreciate that show me. My doubts are:- ¿Where is framework.jar?
- ¿How edit? ¿What I should edit?
- ¿It is works OK or have any know bug?
I tried activate multiusers by terminal and by build.prop but Users still not appear in settings.
Thanks & regards.
My ROM already has multiuser support. Just go into settings and add a user.Randy
Originally posted by rrileypm View PostMy ROM already has multiuser support. Just go into settings and add a user.
I dont have user options in settings, see capture.
I see the 8 value in build.prop for max_users but when I do a pm get-max-users always get 1.
My about tablet description.
Thanks & regards.
Re: Pipo P4 RileyROM 2.0
[ATTACH=CONFIG]9861[/ATTACH]
[ATTACH=CONFIG]9862[/ATTACH]
Thanks & regards.
Sent from Tapatalk on my Pipo P4 running RR 2.01
We've been having trouble with our FTP server where all of the files are stored...Stay tuned, Neomode is working on it.Randy
Originally posted by Billcnz View PostThe only way I found to completely stop cell standby drain on WiFi only model is to delete the system phone apps: /system/app/TelehonyProvider.apk and /system/priv-app/TeleService.apk
There are currently 1899 users online. 0 members and 1899 guests.
