Pipo P4 RileyROM 2.0
Originally posted by m1pnk View Postand can you explain what the twrp file does on the flash.... please excuse the dumbness.... thanks pinky
Also see the TWRP site
Of course it would well be that I misunderstand your question and you are already fully informed, in which case my apologies.
i do have an idea of what twrp is and backup/restore.... but the only time i used twrp before i ended up with a brick..... of course i should go through the motions of due diligence .... but i can backup and install fine using xbmc backup.....just looking to see if i can save time and do it in one quick job.... i have a list of stuff to get to grips with like twrp and flashing..... thank the lord for the likes of riley and others who make it easy.... pinky
Re: Pipo P4 RileyROM 2.0
Originally posted by m1pnk View Postso i install twrp.... try to backup to sd card and i get a popup saying that i cant backup to an sd card because of changes ?... looked for the simple answer on google but its not clear ?.... thanks pinky
Sent from Tapatalk on my Pipo P4 running RR 2.01
Originally posted by m1pnk View Postso that twrp file is just an alternate flash method ?
Originally posted by Damned View PostOk thanks,flashing now.
Any overclocked kernels for RK3288?
Edit:
This version feels a bit slower for me.
Its not the Antutu Score (33 with 1.9 now 34) but while surfing or using apps ect. it feels snappier.
So great work Riley and thank you very much
I have the 3G version of this ROM.
Stay tuned for a new ROM for 3G owners.Randy
3G version is now posted in post #1.
Enjoy!!!!!!!Randy
Originally posted by rrileypm View PostThese ROM's are based on official Pipo firmware. Wifi version #665 dated 10/28/14. There is no new 3G only version at this time.
There was no indication of changes in the firmware, so I can't tell you what is different.
This ROM is:
Rooted Clockworkmod Superuser
Deboated
English default (full language support)
Google Play Store fixes added to allow more compatible apps
Init.d/Busybox support added
Pre-Install added (can install apps automatically from external SD "autoinstall" folder)
Reboot App by Petrus
2, 4, 6, 8, 10 or 12gb user app space (by choosing the desired parameter file).
TWRP Recovery by Abdul_pt
Multi-user support added with changes in framework.jar to activate it.
Edit: Now v2.0.1 to fix boot loop on flashing.
Download wifi Version
Download 3G Version
Enjoy...and please don't forget to donate!!!!!
but the build number is v2.0 instead of v2.0.1 after flashing.
Is it correct ?
If your tablet boots...you have 2.0.1. I didn't edit the version number. 2.0 had a boot loop issue.
Sent from my m7proRandy
Originally posted by rebski View PostHave you studied Stock Android Recovery and Custom Recovery options? If not then some reading and researching would be in order.
Can I flash this Recovery alone ?
Or I have to flash RileyROM 2.0 with TWRP recovery together ?
There are currently 2303 users online. 1 members and 2302 guests.
