Pipo P4 RileyROM 2.0
    Is this a case of Bad Cam?
    My Pipo P4 cam
    M8pro
    M9pro (current tab)
      pic was just a low light problem.
      Will this rom let my P4 charge in an off state?
      M8pro
      M9pro (current tab)
        no
          Boot time
          how long, or how many seconds is this rom's boot time? Stock's at 10secs exact.
          M8pro
          M9pro (current tab)
            Hi ...how many time yours pipo p4 take for full charge??
              Mine takes about 2-3hrs I guess, since I always charge it before going to sleep.
              M8pro
              M9pro (current tab)
                Boots at 16secs, after fresh install of this rom, 10secs at stock rom.
                Bootup takes 45secs with all needed apps installed.
                Antutu Scores at 33K (rom fresh installed and done after first reboot, no apps installed, wifi on). i think this tab will score higher if the wifi is off.
                Battery performance is superb, except for the first 5% after full charge, it will drain fast as this can't charge in an off state.
                Build quality, no complaint on this one except for the cheap design on its front, back is just sexy.
                Wifi is stable, but like the M series, its kinda weak. So instead of modding the tab, I modded the wifi antenna(router) to further its signal range.
                Speakers, it feels like its the same as the M7pro's and M9pro's, but its too weak even after installing Viper. Sound will not compete with another sound source such as noise.
                Fluidity, superb! This is a dream come true for someone who came to experience the M9pro.
                Plastic Clip cover for the multimedia ports, what the hell were they thinking? If you have the original case, you can just remove the cover and it will be covered safely, but it will be the prime entry for dust.
                2gig Ram, can anybody here confirm its specific spec? Is it just a DDR3 dual channel or is the latest LP DDR2? Can't find the answer from the net.
                Btw, what does the #665 in the Kernel version mean?
                Btw2, Thanks Randy! Keep up the good work, and we're continually promoting your team's works in our group, https://www.facebook.com/groups/pipotabletsph/.
                M8pro
                M9pro (current tab)
                  Im getting problem with this pipo p4. In an APP i only have black screen. The video not show.
                    you must be running the stock that has an old firmware. Flash it with this to solve that.
                    M8pro
                    M9pro (current tab)
                      Where can i get this old firmware??
                        you should install this rom, this rom has the latest firmware...
                        M8pro
                        M9pro (current tab)
                          But i have this Riley ROM installed and im getting this problem with black screen in videos in some apps.
                          The original ROM i was getting problem too. I think the problem is KitKat 4.4.4.
                            Fixed the problem I was posting for....
                              please be specific on what apps that makes your videos go black. I have tried 4K videos from youtube and its ok. though I have experienced a video problem on some blog site video I was trying to view. But I have encountered that problem on this rom only once.
                              M8pro
                              M9pro (current tab)
                                In PremiereFc APP that uses flash i only havĂȘ a black screen.
                                The video not show.
                                Where can i download original 4.2.2 version Android for pipo p4? Maybe the problem be this KitKat 4.4.4 version.
