d33 was working on the kernel to fix this but after two trial firmware nothing more was posted
[Pipo Project] M6 Pro
Thanks for answer
Originally posted by spd08 View Posti reported weeks ago that google location service is somehow not working even if enabled
Originally posted by keeshg View PostSorry for asking, thnks for answering. I follow the thread to see if there is news on this.
hi@all, I just flashed the 1.1 on my tablet, runs pretty nice. I just found two issues:
#1:
the "google search bar" on the top is oversized, kind of zoomed. if I create a second user, the size is normal.
#2:
if I pair my smartphone via bluetooth (Sony xperia Z1), it is not possible to connect anymore. since I just have one SIM, I would like to use it for internet access. anyone found a similar issue?
cheers
EDIT:
issue #2 is solved, flashed again and works now. #1 is still a (minor) issue, just look uglyLast edited by tristard; 26 January 2015, 15:50.
Thats it, thanks a lot.
Originally posted by mostafatalaat View PostHello try to flash with 1.1 rom not 1.0 http://www.freak-tab.de/rrileypm/Pip...tabROM_1.1.zip
That did the trick on my m6pro wifi. Everything working OK now. Took some time to get a first fix , but that is normal. (Well I saw that isue with the too large searchbar). No problem with bluetooth. Fast connect with bt-speaker and with smartphone. Not with headset, but that one workes just for phone calls.
Thank you very much,
Kees
hay any body can help me when i flash to rom 1.1 the tab work good but when i reboot tab message came (.com.android.systemui the process has stopped for sorry) when i said ok it came again ok another time when i press power bouton the tab stop and didnt power on until i press restart behind tab and when he start this message again what i do
Does the same problem occur with 1.0?Randy
problems with several games on FreakTabRom
There are problems with several games on FreakTabRom v1.1:
Injustice, WWE Immortals always crash down.
They work well with any other roms.
They're my son's favorite games, how to solve problems?
Edit: I was able to launch them in ART mode only.Last edited by Cusco; 01 February 2015, 19:56.
Originally posted by maakie View Post
Great news, Maakie!!!!!!
Is this built in stock fashion...or do I need to do my usual stuff to it?Randy
There are currently 3293 users online. 0 members and 3293 guests.
