[Pipo Project] M6 Pro
Originally posted by toleman77 View PostThe WiFi 4.2.2. works perfectly with arctablet ROM. With 4.4.2 you do not activate it, stays in "activating WiFi". not think it is router problem because they are not active. Can you think of anything else? thanks for your help
Enviado desde mi V3 usando Tapatalk 2
Re: [Pipo Project] M6 Pro
Originally posted by spyderbilt View PostI have seen this problem somewhere try reflashing erasing the nand
Originally posted by toleman77 View PostSorry for my english, translator use. could you explain how to do it, I've always installed with the program containing the Rom. Thanks
That's because in the wifi version, I turn off all 3G functions...including USB dongle support.
I suggest that if you are using a 3G dongle with your wifi only version to flash the 3G version of the ROM so you can have full 3G support. The only side effect is a little bit faster battery consumption.Randy
Enable SMS
Respected Randy.
How to enable SMS for PipoM6Pro_ROM_150129_3G.
After flashing PipoM6Pro_ROM_150129_3G and Factory Reset I get the SMS function.
But after recovering data from a previous version ROM I lose the SMS function.
How to restore SMS function after recovering data without loss of installed applications.
Thank you.
The problem is with the data recovery.
Restoration of data from previous firmware is tricky...the files might not be compatible with the new ROM.
What method are you using to restore the data?
I don't recommend restoring via recovery across different firmware versions for that reason.Randy
Thank you.
is it normal that i can receive sms but not send?
The previous version of the ROM wasPipo_M6_Pro_FreaktabROM_1.1.
SMS application disappears after data recovery.
Thank you very much.
The M6 Max is an early RK3188 tablet. There are several differences between it and the M6 Pro with regard to internal components. They aren't equal.Randy
Thanks Randy we will steer away from it. By the way the 1.1 rom seems to be totally bug free on my Cyclone Voyager 2 which gets a lot of heavy office use every day. I will try 1.2 when I dont need the tablet for a day or so. Thanks for all the hard work.
Originally posted by rrileypm View PostThe M6 Max is an early RK3188 tablet. There are several differences between it and the M6 Pro with regard to internal components. They aren't equal.
There are currently 1939 users online. 0 members and 1939 guests.
