[Pipo Project] M6 Pro
    Hello.
    I have a problem with my M6 pro. It was working just fine for some days after I flashed it with latest 1.2 ROM version. From yesterday it cannot go over boot animation. It just stacks in it.
    I tried to flash stock kernel, but nothing changed.
    Have you any idea how I can solve it? Thanks a lot.
      I solved it by re-flashing complete ROM again. Now I used alternate stock kernel. Will see if that will help.
        Flashed today 1.2 rom plus kernel.img. Just great until now. D33 kernel somehow makes WiFi unusable. Thanks!
        Inviato dal mio ZP999 utilizzando Tapatalk
          Originally posted by toleman77 View Post
          Re: [Pipo Project] M6 Pro
          The WiFi 4.2.2. works perfectly with arctablet ROM. With 4.4.2 you do not activate it, stays in "activating WiFi". not think it is router problem because they are not active. Can you think of anything else? thanks for your help
          Enviado desde mi V3 usando Tapatalk 2
          I still have the same problem, is there any solution? Thanks
            Hello everyone,
            I am writing this message to say a BIG THANKS to rrileypm, maakie and others who contributed for their wonderful ROM v1.2. I have installed it yesterday and my M6 pro has become a new and very fast tablet. Everything tested so far is working perfectly. Many many thanks....
              Hi. I think, the internal wifi module has died in my M6pro. I would like to use at least an USB Wifi dongle. Does anyone knows, what wifi chipsets are supported in this ROM?
              Thanks.
                Originally posted by diaton101 View Post
                Hello everyone,
                totaly agree - thank you Randy for this amazing ROM. Everything is working smoothly, no problems at all.
                After two years of using m6Pro 3G the battery is dying - I have ordered a replacement on Aliexpress. Hope to use this great tablet next 2 (or more) years.
                  I want do install newer GAPPS but can't figure out how to enter TWRP recovery.
                  Vol+ and Back button and Power-On button does not work.
                  ROM 1.2
                    i have to report my first bug
                    i use 1.2 rom and kernel prepared by maakie included in the rom
                    when i charge the tablet, if it's turned off, it gets stuck on pipo logo
                    and i have to hold power button 10 seconds to reset and boot
                    anyone else / solutions?
                    EDIT: it was already solved with alternative boot
                      Please somebody tell me how to install the GAPPS?
                      And did somebody manage to use the ROM Flash Tool in Windows 10?
                        Originally posted by maakie View Post
                        I've got lollipop running but many things do not work.
                        There is a quite nice running Lollipop here and there is working pretty much everything.
                        Main problem is the awful JB kernel resulting a very lagging device.
                        Would you be so kind compiling a new JB kernel for Lollipop?
                          Hi
                          I use 3G_FreaktabROM_1.2 KitKat on 2 M6 pro tablets, and when i plug the charger with tablet in off state, the PiPo logo is light on.
                          The only way to use tablet again is to press the hard reset. Same issue on both tablets.
                          Any hint, except to use charger when tablet in on?
                          Thanks.
                            Originally posted by Anadax View Post
                            Hi
                            Thanks.
                            READ BACK 4! to #519
                              Believe it or not, i've read almost all until #514 before i flashing my tablets with this amazing ROM.
                              The funny thing is i missed the last one that was solving my problem...
                              Thx for your hint.
                                have you try this rom
