[Pipo Project] M6 Pro
Originally posted by caboom View Post
Originally posted by badbearben View PostI'm using 1.2 as well, but 12 months ago my Wifi stopped working so i sent it back to Pipo and they replaced part of the board and when i got it back the GPS did not work, but noticed that there was a bit of solder on the antenna connection as i had to open it to repair 1 speaker that was not connected, and final got a new GPS antenna and it still don't work (not the roms fault). But yes HDMI works great no problem at all and using HD mode. but i do clear memory before hand. I use video Ultimate Player or the stand gallery video play
https://play.google.com/store/apps/d...d.video.player
https://play.google.com/store/apps/d...d.video.playerif you appreciate my efforts this is the link for any donation:
Originally posted by eliazeno View PostStrangely it reverts to 1 when the battery goes empty...
find file system/etc/init.d/10kerneltweak
open as text
remove "# " from the last line:
# echo 0 > /sys/module/ct36x_ts/parameters/wakeup_enabled
save changes
reboot
open as text
save changes
reboot
but i confirm the problem during charge, can't boot the tablet and screen stays always on, showing the pipo logo
Originally posted by maakie View PostFlash this boot image to fix the charging problem.
I've noticed a strange behavior with wifi. For no apparent reason my default wifi networks disconnects changes state to Disabled and I can't automatically reconnect to is (must manualy tap and choose Connect).
Thanks 2 maakie.
after ~two weeks i was on my way to write that everything is working.
Well it was until just now. My battery was low (4%) so i made a shutdown and connected the M6 to the wall wart and the cover was closed.
I was on my way to use it and opened the cover and did realized it was on and hanging where it says "Pipo interactive media".
Is it normal the tab turns on if you connect the charger?
So now it's hanging there. I can push the power button for some time and it goes off but turns on again after 5 seconds.
Pushing the reset also makes no difference.
The M6 was running the whole time without crashing or hanging :-(
EDIT:
After unplugging the wall wart and pushing reset it stayed off. After pushing the power on button it booted and started normal?
There is just one thing that does not work: the camera...
I get the message "Camera error - Cannot connect to camera"
I'm the only one? Cause searching this thread for "camera" returns nothing.Last edited by MrGlasspoole; 31 March 2015, 12:21.
And solution : post #417
I did have the same issue!
Hope its the same for you.
If you need more info, pm me.
There are currently 4208 users online. 1 members and 4207 guests.
