ShaunMT
Nexbook AMlogic root WORK!
Originally posted by Jds View Post
ShaunMTFreaktab Rom Developer
Originally posted by dredredrizzle View Postif anyone can post a stock image to the amlogic 7p12-8g I'd appreciate it a lot! I have one that's just sitting here dead, seems the stock android image just decided to break itself after a while, the hardware looks like it's functioning normally.
dose this method works on the NEXTp12-4g?
Hi guys i am new here
I have a nextbook Permium 7 se (nextp12 4g)
with serial no:YF06133XXXX
and OS Android 4.0.4
manufacterd jun 2013
I want to uplode Arduino sketshes from my tablet
the OTG works fine on keyboards and usb flash drives but when
i connect the Arduino board the ArduinoCommander app and the
ArduinoDroid app says "no board found" but the USB Host Controll
app recognize the Arduino borad
dose it need to be rooted or not?
and if so is this the proper way to root it pleas help
thanks in advance
thanks in advance
For full root, use Cydia Impactor.
a quick google search will find it.
Originally posted by SilentEagle View Postthanks allot that solve my problem
Impactor says "device not found"
I've installed the driver-package mentioned on Cydia Impactors homepage and even the Windows-version of Minimal ADB and Fastboot.
Next7P12 4G
Serial No: YF041304...
Android 4.0.3
Depends on where U are.
Originally posted by bryman777 View PostIf you remove the cover you void your warranty..
But I would like to do a very different thing – I wont my tab with DebIan. Of course standard armhf-DebIan with no more of an Droid mess.
cyber
Originally posted by purplepeopleeater View Postwould you kindly post it I can't get the correct driver nor understand what to do with the files for my NX008HD8G
Do you have an external micro SD card?
I'd be happy to help you install the files I posted here for the NX008HD8G:
Originally posted by purplepeopleeater View Postwould you kindly post it I can't get the correct driver nor understand what to do with the files for my NX008HD8GNextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
AML8726-M3 Cortex A9 @ 1GHz
Nextbook Premium 8 HD (N0008HD8G) - * ROOTED *
Nextbook 8 (NX785QC8G) - STOCK (unfortunately)
Next7P12 4G
Android 4.0.3
then activate usb debugging in setting then connect ur device to the pc
it should install the drivers form microsoft servers
this worked for me
Nextbook 7p12 with google play
I have got a NEXTBOOK 7p12.
After 3 days of endless reading and messing around with the tab finally rooted it with Impector.Checked it with root checker from google play.
OBJECTIVE : 1. Install CWM recovery.
2. Flash CM 10.1
But here's the catch, even after rooting i am unable to install CWM. tried nearly everything from here and xda.Nothing seems to work.There is no official version of CWM for my tab.
Specs: nextbook 7p12
s/n: YF 0513...
PHM727MC (i dunno what that means)
Also tried update.zip by BOB. Some .img file too.When in stock recovery it keep showing segnature verification thingy.
Can anyone please tell me what to do next as i am hell bent on either flashing it to CM10.1 or BRICK IT !!!
2. Flash CM 10.1
s/n: YF 0513...
There are currently 2618 users online. 0 members and 2618 guests.
