Nexbook AMlogic root WORK!
Thank Goodness
I've got a rooted 8HD8G and almost given up trying to find a custom recovery until I read this thread. I'd be happy to help how I can, I'm not new to rooting and I have a basic grasp on how to do things. But only with phones though, I'm not any kind of developer by any means at all. This is the longest I've had a tablet .... Going on 3 days now lol I hard-bricked the first one, and broke the screen on the second one. First was a Dragontouch RK3066 7", second was a Dragontouch RK3066 10.1".
**Edit**
The method I used for rooting was actually located in this forum on THIS particular thread lol
Amlogic Next8P12 Stuff
I heard from Finless today and some of my files for the Amlogic Next8P12 should be posted soon. The first release for this model will include a stock rom, a modified stock recovery bootable from SD card, a flashable root package and a flashable Gapps package.
And here is another teaser for you... I have CWM Recovery booting from SD card on one of my Amlogic Nextbook models! It is not working correctly yet, but I am close...
Thanks for being patient everyone.
ShaunMTFreaktab Rom Developer
Originally posted by jusbla12345 View PostOn my Mac, I installed ADB using this link
plugged my device in, and then downloaded this program
and it rooted my tablet. I then just had to install SuperSu from the store.
It's the first and most probably only working root for it
Originally posted by shaunmt View PostI heard from Finless today and some of my files for the Amlogic Next8P12 should be posted soon. The first release for this model will include a stock rom, a modified stock recovery bootable from SD card, a flashable root package and a flashable Gapps package.
ShaunMT
Originally posted by Tread View PostShunMT: It worked, I'm officially "teased", if you get the CWM working on this thing you may want to post your paypal info... I'm just saying
This leaves three options:
1. Port one of Christian Troy's ainol recoveries with his UBIFS support mods. (I'm testing currently, but I'm not sure he worked out all the bugs in the versions I can find.)
2. Manually build CWM from source including Christian Troy's UBIFS source code. (It is going to be awhile before I can get around to this.)
3. Convert our Amlogic Nextbooks from UBIFS to EXT4. (This seems like a good idea to me, but I need to learn more about the processes involved before I risk bricking my tabs.)
Originally posted by jeqbrown View PostThanks for all of your hard work!!! Will the above files work with the Next7P12 also? If not, do you expect a soon release that will? I am trying to learn to create my own roms, but for now I think it better to leave it to the pros....
Are you referring to the older Rockchip based Next7P12 or the newer Amlogic Next7P12-G with Google Play from Walmart?
I plan to release some files for the Amlogic Next7P12-G soon.
I'm no pro... but I am learning quickly...
Originally posted by shaunmt View PostNo, these files should not be used with the Next7P12.
ShaunMT
Originally posted by jeqbrown View PostThanks ShaunMT. I am referring to the newer Amlogic. It registers as an M3-chip... I just recently bought two of them thinking them a really good deal for an 8gig tablet. It only took about 2 hours before my son ran out of 'app space'. It seems they only allocated 397MB. I am hoping a newer rom will overcome this?
I intend to release a stock firmware for this tablet in the near future, but it may be awhile before I can do any modifications or custom ROMS because I don't own one of these models to test on.
Originally posted by shaunmt View PostThe "8gig" is split up between the system and the internal "sd card". It might be be possible to adjust the partition sizes to increase the app space on a modified ROM, but I think the best solution would be to install a 32GB external SD card and then swap the mount points so the system thinks the external sd card is the internal one and installs the apps to it. There are apps on the play store can do this.
ShaunMT
Originally posted by greggwv View Posthave tried using adb shell
shell@android:/ $ su
su
Permission denied
1|shell@android:/ $ anyone know of a way to get rooted? thanks
Also, I plan to send Finless a modified recovery and flashable root package for this model this weekend.
Modified Stock 3e Recovery, Stock ROM and Flashable Root Package For Next8HD8G Posting Soon
I have finished a modified stock 3e recovery, stock ROM and flashable root package for the Next8HD8G. Files should be posted soon.
The Next7P-8G is next. I don't own of these. I still need some stock dump files, and I'll need a tester or two.
There are currently 1838 users online. 0 members and 1838 guests.
