Edit: here are my videos for this box.
Tronsmart TV Box Ara X5 in August with Cherry Trail Z8300 Windows 10
Originally posted by Fozzie View Post
Thank you for your reply. What is the ambient temperature in the room where the device is?
It varies but at it's hottest, I used the box in a room temp of around 28C and inside an enclosed TV cabinet, which would likely make it even warmer.
Trebor, I have done all that as a work around and it works for Kodi and some other apps. But it does not work for some other things, like mapping my HDHomeRun tuners in Plex or Emby. I spent several hours on the phone with Microsoft and talked to at least 8 or 9 different people. The final solution they told me was that I needed Window 10 drivers from the makers of my NAS, which is total bull.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by clarkss12; 12 October 2015, 12:33.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
OK Understand fully the problem now,
Good video.
I use Plex Server on a PC as server with WIn10 with my WD Duo Nas(off sorts)
As it detects I guess its easy .
MS must have dabbled and the function you seek is hidden/disabled or oops they forgot.
Will watch with interest for the final out come.
Cheers
As yet no, Box not here at present, when it does I will
As mentioned I do have it working on a win10 Laptop presently home vesion.
Dont know if you have tried this
Try sharing the folder that holds the media and not the root of the drive if not already.
my Y: drive = Y:\TV
So in Plex when adding and I browse it can see Y: that is all the DIR of the Shows
What I have done:
I just received my Teclast x98 pro Tablet. Teclast X98 Pro Tablet PC Intel X5 - Z8500 Quad Core 2.24GHz 9.7 inch QXGA IPS Screen Windows 10 + Android 5.0 64GB
Win10/android 5.1 etc...
So once setup I installed Plex Media Centre
I shared the media files on the tablet as mentioned above: as in y:\media
Set up new media type TV
Browsed with tablet to NAS in Plex found files, "y:" downloaded/synced to files to DB then did the meta data etc.
Played on Tablet from server fine
On my new Zidoo X6 using android Plex, I set Plex up to a manual setup to look at the Teclast X98 tablet Plex as apposed to the other Plex on laptop
that worked I now of two Plex servers.
Found the Media server found the files and played 100%
Working well
Cheers
Working well
Cheers
There are currently 4114 users online. 2 members and 4112 guests.
