R-BOX Android 5.1.1 RK3229 2/8GB KODI 16.1 4K 10/100M LAN Bluetooth4.0 WiFi HDMI DLNA - Silver/ Black
    Yes its a hardy little box better performance then i expected. I think do to too the 2 gigs ves 1. The other 3229 firmware listed in thread all works with this device. (switching resource kernel ) net box is kk though but it works. Seems they all have similar set ups and showing same 5 gig not in storage. Firmware updates been a huge bonus better then the qbox response. Seems similar to 3288 in bricking and un bricking get to mask mode everything works fine again.
    Cyber re her shoes its knowing when to bring that subject up is critical. Like just after you hear her gasp when the visa bill shows up.
    Heading out fishing test video and play back later... All in thinking i wss buying a new clock and i got a working tv box i am happy. 😁
      HAHAHAHA!
      kind regards
      cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
      http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
        'Sco NAN, b'y?
        (...I turn me back fer a minute, and...)
        Remember me caving to my friends' demands I hand over the boxes last week? Well, my "friends" are sending "my" 2 boxes back to me, and I won't be able to get any relevant info out of the guy who's dropping them off (he's kept in a cellar to "keep him quiet" when he's not delivering stuff. I'm told.) so I can't interpret "They're not working out" at this point.
        May I assume from recent posts (and the conspicuous absence of recent complaints) you guys have the reset-over-ethernet gremlin quashed?...
        Say it's so, Joe... Say it's so.
        "...Hear about the devil worshiper who had Dyslexia?... ...He gave his soul to Santa..."
          Reboot bug was squashed with the latest full image followed by a couple of tiny OTAs. I think your friends will be happy with their budget boxes.
            About the dyslexic, now he will spend eternity making toys.
              To confirm this would/could/should be the latest firmware up to date if going buy date stamp and test keys
              This was achieved by latest .img file and followed 2 OTA updates.
              There has been OTA for me here as yet last 24 hours but the day is young anything is possible
              Cheers
                Originally posted by dpanijan View Post
                Well, I was googling and reading forums and found the solution for my problems
                To get it to work correctly in 1080p, I have to run the following commands as root (in terminal):
                su
                wm size 1080x1920
                wm density 240
                To change it back:
                wm size reset
                wm density reset
                It is not my discovery, but I hope it helps
                dpanijan Welcome to Freaktab. Thanks for the tip.
                Has anyone tried this yet?
                It did not work for me, as it did not fill the screen. Also I rebooted after, still only fills the center third of my 1080 display. Have to look in to it further. Any ideas? Would the build.prop also require modification?
                  trebor Confirmed here, same as yours. 20160628.203608
                    I put it into the firmware section. 0615 does one ota but not to latest version so ill remove it and put the 2 ota in same firmware link. That way less confusion.
                      Is this the same box or could it be a clone?
                      https://www.amazon.co.uk/iLepo-Mirac.../dp/B01FSSPP2G
                        Wierd remote everything look the same. See what geek buying say.
                          Cheers.
                            Hi guys, been playing around with my r-box the past week or two.
                            Noticed something strange has started happening. When I use the remote control it works fine for a minute or two on booting the device. But then the cursor will freeze on the screen. It'll only let me move the cursor a few millimeters!
                            Now if I wait for, say 30 seconds, the remote acts normally for 2 or 3 seconds before freezing again. If I wait for maybe 5 or 10 seconds, it'll only work normally for less than a second before freezing again...!
                            Has anyone else experienced this? I've tried flashing firmware from pc in an attempt to reset the device, but no joy.
                            Funny thing is, it was working fine a week ago until I decided to do an ota update.
                            Any suggestions/help would be much appreciated!
                              Yes check your storage and see if your out if memory as well make sure all apps have been closed. One of the reasons i trying to get storage increased.
                                Clear cashe in storage should help as well.
