When it picks up the presence of the correct version then it will prompt you to use it.
Alfawise S92 TV Box Octa Core Amlogic S912 Android 6.0
Originally posted by gorditogr View PostI own this box since yesterday.
Already did 3 updates, i'm quite happy with the support Alfawise has shown!!
My problem is that i cant play DTS audio with MX player, i tried with some 'custom codec' i found on XDa, but it didnt work
Do we have any options?
Originally posted by norco53 View PostThe OTA updates should work fine, as long as you did not edit your build.prop file (to compensate the dark video problem).
It's not possible to change that param back?
If not, what are my options now to do an OTA update?
Originally posted by mnale View Post
Uh-oh. I did change that (dark video) parameter in the build.prop file (following the Youtube vid).
Originally posted by norco53 View PostYou should be able to edit build.prop - putting the parameter back the way it was originally. Then perform your OTA update.
All is well.
Originally posted by m0rph3u5cro View PostHi all. After OTA update my firmware is S92_111M0. My homescreen gui have changed and now it is called bee gui. See picture. Is this ok? Thanks.
Sent from my LG-D802 using Tapatalk
With this latest update, I am unable to permanently change the clock from 24HR mode, and the Temp from C to F. The options are there but they don't stick once changed.
I can't get DTS HDMI audio pass through to work on my Alfawise S912 with Kodi 17.1 and latest firmware.
Dolby Digital works fine in pass through to my DTS capable receiver. Any suggestions?
Update: It appears Kodi 17.1 breaks DTS. I went back to Kodi 16.1 and DTS is back. Hopefully Kodi or AML will get this working.Last edited by mnale; 09 April 2017, 22:42.
There are currently 2186 users online. 2 members and 2184 guests.
