Alfawise S92 TV Box Octa Core Amlogic S912 Android 6.0
My Wi-Fi antenna mod
this is an antenna from a Spectrum DX-4e/DX-5 2.4GHz r/c radio.
I drilled a small hole through the case for the wire and 3/8" of the small antenna support that sticks out the bottom of the black outer casing. Currently the outer casing is simply epoxied to the case. I do believe their is room for a small chromed screw or two to hold the base firmly to the upper case.
the hardest part was marking the hole so the offset internal casing and outer casing aligned well in the corner. This is not really even difficult as there is a good bit of room under the base to enlarge the hole if needed.
I wish I would have got a shot from the bottom to show the fit of the inner casing as it is pretty tight and looks much like a factory job.
these antenna mods are a good idea for almost anyone who can solder and has their router in a different area of the house.
ideally one would want to add a small coax connection to the side of the case to accept a wide range of Wi-Fi antennas.
Edit: Test show an increase in basic signal rating from fair 2 of 5 bars to good 4 of 5 bars. I currently don't stream from my old laptop which has one of its 2 old 200gig HDDs full of movies and music from days gone by.
here is a screen shot (lol read crappy phone camera shot) of Wi-Fi analyzer I was only showing two networks in settings before mod.
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by kinezos View Post
4.4.2 is the android but i don't think is the software problem. But i'm not an expert so please if you know anything...
Format the drive again with the box and see if that resolves the issue.
I have seen a similar problem with Marshmallow.
Originally posted by aelfc(larissa) View PostNai kineze, I had this problem, I believe that this happens only to usb sticks that their file system is been corrupted due to not using the safe abolishment of the os. Try to copy all the files and then format the usb when S92 asks you. For me the problem solved.
So this is i think the newest .img for s92 that i got here from user Gearbest: https://mega.nz/#!akAgEIpQ!sf2vQ15hr...vQKdaLuMuR495Y its S92_109M0.img
So i just download it on my box and manually update from box ?
Originally posted by inkognito3 View PostSo this is i think the newest .img for s92 that i got here from user Gearbest: https://mega.nz/#!akAgEIpQ!sf2vQ15hr...vQKdaLuMuR495Y its S92_109M0.img
http://freaktab.com/forum/tv-player-support/allwinner-tv-players/freaktab-tools-utulities-collection/583686-usb-burn-tool-2-0-7R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by diaconusm View PostHello. There is a fix for updating the system. Changing build.prop (service.bootvideo = 1 from 0) will result in getting the message "your system was damaged, wireless update is disabled!". Change back the value from 1 to 0 and then just update. The path is: Local-device-system-build.propso after all updates brightness is good or we have to change it back again to bootvideo=1 ?
Edit: yes we have to change it back to bootvideo=1 just tried itLast edited by inkognito3; 05 March 2017, 12:09.
Originally posted by zenix View PostThe old trick for the brightness was to play a 4k video for some seconds. If you edit the bootvideo value to 1 , makes the same resault like the 4k video or playing the 4k make the box more brighter?
There are currently 2298 users online. 1 members and 2297 guests.
