How do i boot to recovery? so i can't go into settings and do a Factory reset like on this picture?
Alfawise S92 TV Box Octa Core Amlogic S912 Android 6.0
Originally posted by labalele View Post
I was responding to somebody else regarding using recovery at the time and cross posted lol
You can look at the details of the firmware in settings to see what version that you are currently with.
I stopped using the stock firmwares a while back because there is an excellent and much better custom firmware produced by FT Developer Superceleron.
So it is worth looking at installing this
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/others-aml-s912/firmware-roms-tools-by/611261-rom-beelink-gt1-alfawise-s92-superceleron-v8b-rom
Originally posted by labalele View PostOkey thank you!How do i backup my android box first? with the Update&Backup app that comes with the box?
How did you connect the box to your pc when using burning tool? s92 has no micro usb port?
There are 2 methods of flashing and image.
One using a USB Male A to Male A cale and the other using a micro SD card.
Details of how to use the SD card method are detailed here.
http://www.cnx-software.com/2016/11/19/how-to-create-a-bootable-recovery-sd-card-for-amlogic-tv-boxes/R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by labalele View PostOkey! perfect! then this will be my last question : Where can i find the stock firmware? Can you link it ?want to know that before i start
thank you !!
http://freaktab.com/forum/advertisers-and-vendor-support-area/gearbest-com/608058-alfawise-s92-firmware-downloadR-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Stock firmware is available here
I have the same problem after tried the FOTA in s92. Box says that system is destroyed and wireless update is disabled. After making factory reset from settings (not twrp), the system boot up with no problem and if i try fota after,it finds the update again but i still have the above problem. So the problem is not how to flash the rom again but how to make the last update, so i will keep having fota in the future. Any idea ? If i try factory reset from twrp and then try fota again? What do you think, my friend, is happening with this OTA? the file is corrupted or something else? Because last two ota updates went fine
Please, what are the settings in usb burning tool. I am trying to flash sc rom but get error result
i connect s92 to a win10 laptop. I use only a usb cable and the programm says: HUB2-4 connected. I choose normal earse and erase bootloader
after connected to pc should be power on the box or no?
always stops at 96% and says: result: Uboot/Temprature Testing/Get result/out of rangeLast edited by zenix; 17 February 2017, 11:12.
Is the h96Pr0+ the best of the boxes to get right now? I have the Beelink GT1 and its okay..ordered the 96pro+ though. I am hoping by now they have ironed out most of the issues. my gt1 runs okay and I have got it to stop crashing but I would like better support. seems like beelink doesnt really care whats wrong with their product
Haha i just did this on my alwafare s92, after boot i still ahd all my apps left, is that how it should be? now i wounder, why did i do this? whats the good thing about doing this ?tell me
EDIT * now i dont have sound on iptv ac3 5.1 anymoreany fix for that?
EDIT* Sound works now after i enable root ? haha
There are currently 3092 users online. 1 members and 3091 guests.
