Alfawise S92 TV Box Octa Core Amlogic S912 Android 6.0
Yeah well the thing is, the Wifi itself is fine. I got great speeds on all my other devices but this one. I could of course say, as long as it works, but I believe if the speed is so much worse than what it should be, there must be something wrong with the unit. I'm probably going to return it.
Originally posted by Omiros View PostHi, I can not update Play Store. I was try everything, tryied to install apk, manually check for updates via play store settings, hard reset, but still refuses to update. Any Ideas ?
Today I've tested the 5Ghz Wifi again and for some unexplained reason it finally reached the full 75 Mbps. I have no idea why. The only thing I did was to empty the cache of the google play services but I didn't test the speed before that. Just wanted to give an update. Seems like I'm going to keep that thing.
Originally posted by Al33 View PostI gave up on the Wifi of this box. It went back to a bad reception shortly after my initial problem with it went away. I'll keep the box though. I have it connected via LAN now and that works very well. So if you wanna buy it, keep the bad Wifi reception in mind.
There are currently 3100 users online. 1 members and 3099 guests.
