Alfawise S92 TV Box Octa Core Amlogic S912 Android 6.0
Originally posted by zenix View Post
For info about alfawise products, firmwares, e.t.c
This would be the closest.
http://www.tvboxforum.com/R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by zenix View PostReceived today. Till now satisfied. Only one thing. Sometimes when i play around, the language change from english into chinese. It s disturbing. Can i do something about it?
Originally posted by deebee123 View PostJust placed an order for one of these, currently $59.99 at GB.
I know I want to swap in a new launcher. Haven't decided whether to go with the Superceleron rom or stick with stock.
anyone who has used both care to commen?
If stock had been adequate then there would be no reason for a custom firmware to fix the bugs and enhance features.
Thanx
Suppose we use a spmc or ftmc with a build we like and these two app will be updated, we must install the build again or not?
Thank you
Superceleron build all the way.
Thank you but i asked if i must install again the kodi build i use when spmc/ftmc will be a new version
If you are using a more standard Kodi build then in order to install FTMC then you would need to uninstall Kodi as you cannot have Kodi and SPMC installed at the same time.
SPMC uses a different file structure though, so you can have Kodi + SPMC or FTMC + SPMC installed at the same time.
Hello everyone im new here! i got my s92 box few day ago
Sorry for my bad english!!
But today i got a message that there was a new wireless update. So i start the update and i got this message "Warning Your system was damaged. wireless update is disabled!" OK? same message everytime when i try, i did the update with cable and not wifi.
What to do now? i can still use the box but cant uppdate it. Someone else with the same problem?
// Laba, sweden
Originally posted by labalele View PostHello everyone im new here! i got my s92 box few day ago
// Laba, sweden
I have read somehere that you can do factory reset and after you can make the update.
Found any solution?
// Laba, sweden
There are currently 3374 users online. 4 members and 3370 guests.
