[ROM] Custom Sunvell T95Z Plus Amlogic S912 With 9377 WIFI Chip
Originally posted by amhonra View PostI received mine and it comes with T5ZP0063, I flashed TWRP and did a backup before, IF somebody needs something from this backup please let me know
android 6.0.1
3GB / 32 GB
q200_9377_3G
So I installed this rom. Seems ok.
I have 1 question, 1 concern.
First you speak of modifying the wifi and that the 5 ghz is no good and you tweeked the 2.4. My question is about the 5ghz did you leave it the same as the source firmware?
Second, your firmware is installing netflix however if I want to install netflix on google play it states its not compatible with the device (my original T5ZP0031 firmware did not have that issue) Can that be resolved?
Also thanks for this.
James
Edit: I found a fix to my second question, I can just edit build.prop in root. Now I just need to know what device I should use.
Will this work? Im not looking to get netflix HD just the basic app. I know I can sideload it if it doesnt show on google play but I would like it to show on google play so it can auto update as Im setting this up for my parents.
Also on a side not any way I can change the KODI tile on the launcher? it used to say KODI now it says KD player and Ide like it to say KODILast edited by 007; 09 May 2017, 21:50.
Originally posted by MartBiOs2k View Post
Yes I added an boot Image that represent the shape of our box and a kind of signature
thanks
Regards
Regarding the wifi mod i've found a way to increase the range and signal strength further and stronger than the way you've done it. It is basically the exact same way as yours apart from 1 single part. Basically where the wifi cable joins the board, if you follow the trace back towards the wifi chip you'll see a resistor in place which needs to be removed as it tunes the signal to use the old stick on ariel . You can either remove it fully and solder across the pads or just solder over it as it'll stop it working anyway! I found once I did this it improved the quality and reliability of the signal as well as increased the signal that it saw on 5Ghz!
Originally posted by MartBiOs2k;n627174
[SIZE=16pxWIFI antenna upgrade MOD[/SIZE]
As you know, WIFI is not very good in this box, so I decide to boost it up to full performance.
Stock the t95z plus have a 1-3 dbi tape antenna that have about 1/3 stick on the side and 2/3 stick on the bottom of the plastic case.
So I ordered a SMA pigtail and a 7 dbi sma antenna (2.4GHz+5GHz)
I've un-soldered the original antenna to keep in case I want to revert my MOD. And soldered the SMA pigtail and drill a hole in the only side free of port and connector
WOW !!
In 5GHz AC 433mbps @ 20 feets + 2 walls I'm at 92% signal quality compared to 58% with the original one.
in 2.4GHz N 150mbps @ 20 feets + 2 walls I'm at 100% signal quality compared to 70% with the original one
Resulting no buffering with MKV and MP4 1080 over network share
Are you using the original HDMI cable that came with the box ?.
if yes, try a different cable that you know it work. the thing they ship with the box are cheap cable and my give you more trouble then good
let us know
I have changed of input and HDMI cable (with one which works on another tv) => still the rgb issue.
I don't think a solution will come but thanks for your help anyway.
Originally posted by h4x0rm1k3 View PostRegarding the wifi mod i've found a way to increase the range and signal strength further and stronger than the way you've done it. It is basically the exact same way as yours apart from 1 single part. Basically where the wifi cable joins the board, if you follow the trace back towards the wifi chip you'll see a resistor in place which needs to be removed as it tunes the signal to use the old stick on ariel . You can either remove it fully and solder across the pads or just solder over it as it'll stop it working anyway! I found once I did this it improved the quality and reliability of the signal as well as increased the signal that it saw on 5Ghz!
KindRegards
Hi MartiBios2k,
I have a Mecool M8S Pro, the 912 chipset 3gb ram and 16Gb Rom, the WIFI chip is QCA 9377, besides the RAM ROM and WIFI chip, it is the same as your t95Z. The box comes with Android 7.1.1, I want to root it, or install firmware with a lower version of android (This is to get around some of the security issues on some of my streaming apps). Would your firmware work on this box?
Regards
Leon (South Africa)
Originally posted by BrainStorm View Post
Thanks for all Bro, hey take a look https://mega.nz/#F!xlwAmIrD!Dg_1Kqgl1Jp0eGB67fV7Cw this is the last version from gearbest, you make your custom firmware from this version or the version from gearbest is more new?
Regards
Regards
Leon (South Africa)but before that, be sure to have the original firmware in hand, and all tools and software to flash it with amslogic usb burning tool
android 6.0.1
3GB / 32 GB
q200_9377_3G
There are currently 2688 users online. 1 members and 2687 guests.
