[ROM] Custom Sunvell T95Z Plus Amlogic S912 With 9377 WIFI Chip
Hi guys .
I have the 6330 wifi chip and it doesn't work after this update.
(The original firmware was T95ZP0009)
But that is ok because I use an ethernet connection.
My biggest problem is that the bluetooth doesn't work either and I use a Bluetooth keyboard
I was really happy to find the RGB setting but without the Bluetooth it's still worthless..Last edited by Nardo; 03 April 2017, 13:59.
Hi buddy, I recently purchase T95Z plus from gearbest and was a crap the firmware, now I installed your custom firmware and the wifi work like a charm, the only thing that when the system starts in the screen appears a background and the icon of android, please keep updated always with the last firmware, you Rock buddy
many thanks!
Originally posted by vmax377 View PostDisconnect the t95z. Press and hold the reset button. Connect the t95z and wait for it to turn on in recovery mode
is there another was to flash that ROM?
Originally posted by fuuman View Post
Okay, that's working, ty. But it's still not appearing in the USB Burning Tool in that mode. Drivers installed.
I understand that you use Amlogig usb Burning toll? Try using the other usb port of your T95z, there is one that is not recognized, and connect it to the pc while holding the reset button, I went crazy with this
Can you explain it in details pls? I am going crazy like hell. I tried absolut every order and USB-Port and there is no chance to get a connection.
When I have to start the software? At which point I have to plug the device in? Please help me
Yes, i use that tool in version 2.0.8
Hello I use version 2.05.15, before installing the program connect your t95z to the pc so that the drivers are installed.
The correct usb port is the one on the right of the display (next to the network connector)
Open the usb tool program Connect usb cable on your t95z
Connect now to your pc usb and should be recognized (connect success)
This is how I do it, if it does not work try version 2.05.15
Good luck
Thanks for your great work !
For information I run you Firmware on a M9S-PRO (Leelbox-tech) also S912 with LTM8830.
I change from the original firmware because I found some bloatwares with the apps named Chinese Backdoor Malware check. Unfortunately, I still find fota.sysoper and/or adups.fota malware backdoors in yours. I will inhibate them but would be great to eliminate them as none of us needs an update tools from the native firmware.
There are currently 3188 users online. 1 members and 3187 guests.
