[ROM] Custom Sunvell T95Z Plus Amlogic S912 With 9377 WIFI Chip
Only issue is getting temps down. Active cooling would be good but in don't think I can find a usb powered cpu fan that is 1 inch x 1 inch.
My box seems to idle as low as 55c (approx 136f) with the lid on. Playing local media off my usb hard drive doesn't raise temps too much too quick but using kodi to stream content will, and the box completely freezes up at 75c
Originally posted by batkinson001 View PostOnly issue is getting temps down. Active cooling would be good but in don't think I can find a usb powered cpu fan that is 1 inch x 1 inch.
Originally posted by Doughyboy View Post
I found the overheating to be an issue as well so I've gone back to the superceleron rom. I'm using ethernet so no issue giving up the wifi to keep the box cooler. I see someone has requested he update the rom to work with the 9377. Here's hoping...
I am all for the other rom doing the job. I would love it if it caused the system to run cooler and not freeze or lock up, especially when using kodi to stream, which I have also been wondering if certain builds cause issues like freezing or locking up, I use retro mania which is quite big on space...
Using the superceleron rom and watching videos with Kodi for a few hours, temp maxed out at 145F/63C and the box is warm to the touch. Never checked before switching roms but I know on the original that the box was much hotter to the touch. The superceleon rom also fixed Kodi crashes I was having along with the dark video.
Originally posted by MartBiOs2k View PostHello everyone,
I've made a custom firmware from the source T5ZP0032.
please note that this firmware is only for T95ZPlus with 9377 wifi chip!!!
My modifications:
- Added a boot image splashscreen
- Cleanup of preinstalled application
- Fixed Keyboard mapping for ENTER key
- Added TeamViewer AOSP addon (remote control your box with teamviewer)
OTA Option are there so will receive next OTA Update and probably wipe my configs
You need to flash with amlogic bruning tool like other firmwares (choose erase flash(Normal erase) and erase bootloaded)
It take about 5-6 minutes to load firmware....
after the first boot, give 5min to preinstall task to finish, you will see apps popping in your menu. do not connect your wifi or open anything during this time!!
Download Link Updated (T5ZP0032)
https://mega.nz/#!NpwSXKLL!sto07FVuw...ChZE3WSvw3IUkQ
If so, I may have it already from another thread.
The version number matches. Mine has the official t95z boot screen before the usual animation. And Kodi is renamed kd something.
Is this in updated build the one with the sky something or other app?
That rom is contained in this thread and is a custom rom created by martbios2k which is based on original stock firmware T5ZP0032. It has minor tweaks only and does not address any of the issues that are fixed with superceleron's rom.
Update: supercelerons rom works but I have no wifi.
Which really sucks for me.Last edited by batkinson001; 23 February 2017, 03:11.
My modifications:
t95zplus_q200_9377_customV1.6?
I will give supercelerons' rom a go tonight. Hopefully it works with my box. If not I can always flash back to this. My major concern is the heat my box generates. I can run it with the lid off but it doesn't look right.
What are the differences between this and the previous version of the rom which you recommended to me...
There are currently 2321 users online. 0 members and 2321 guests.
